VXR-7000 Programming issue and question
Muscatine, IA
Hi, everyone,
I have a VXR-7000 running version 1.19 (or 1.18, I'll have to look again to make sure). I want to set the receive frequency to 447.975 and the transmit to 442.975, but whenever I upload it to the repeater, it flips them around. I'm using CE27Win 1.08 to do this. So, my questions are is this typical of the repeater to push a +5MHz offset instead of letting you set a -5MHz offset? (In other words, I'm I stuck with the lower receive frequency'higher transmit frequency)?
It also resets the RX adjustments and TX adjustments. And I've been using dealer mode to set it up. One more question. If I have to use the DOS version of the program, will it recognize the COM Port that my USB cable is on?
Also, am I using the correct version of the software for the firmware that I have?
Thanks, and have a great day. :)
Patrick.
radiotweester
Oregon
Windows version you have is right. Try the /m like I said in the other post. I don't have a repeater in front of me, but the program doesn't seem to try to correct them.
Dumb question, but are you using the correct band split fot HAM or trying to bring a commercial 450 down to HAM? If it's the latter, changing the TX and RX adjustments allow programming the freqs, but make sure you actually calibrate using a monitor (I say this not knowing your experience). 73s
Muscatine, IA
Hi, there,
Yes, the repeater was a commercial one (I'm guessing since the TX adjustment was 455 to 480). The person who's actually building the repeater has plenty of equipment and experience in calibrating it. He has the duplexers already calibrated for the frequencies we are going to use.
I'll try the /m (or -m in my case) this afternoon. Can you tell me exactly what mode that is (and what modes are available)? Until I found this forum, I'd only heard of the /d (-d) dealer mode, which we had to use to get a blank code plug for the radio.
Patrick.
radiotweester
Oregon
/m is ALL access. "manufacturer" mode. I tried the space /m on a windows 7 OS
the -d use to be used as "dealer" mode in DOS and would allow CW ID access
*Don't use a blank or default codeplug, read the radio, save as, then edit that read file, save as a different name and then write it back to the radio. Pretty much the rule with Vertex and Motorola.
Muscatine, IA
So, let me say that we figured out the programming problem. And I hate Vertex Standard (not really, but whoever designed the program needs to have their computer smashed). On 99% of the software that I use, "Download" is coming from the device to the computer, and "Upload" is going from the computer to the device. After about 30 minutes of "I screwed this up, and don't know why", I figured out that whoever designed CE27Win configured those backward. So, we were able to upload our code plug to the radio (or Download as the case may be).
Now, we're working on getting the repeater to talk to the controller, and thus Brandmeister.
Thank you for all of your help with this, and have a great day. :)
Patrick.
radiotweester
Oregon
Patrick.
Glad you found the problem! I didn't even think to ask if you had the toolbar showing. For others reading [View] -> [Toolbar]. SO MUCH easier with the graphic showing an in and out.
85234
Muscatine, IA
Just curious... How does an FM repeater talk to Brandmeister?
Hi, Chief21,
So the repeater sends the data as audio to an external controller, which is an MMDVM modem mounted on a Raspberry Pi. The modem converts it to data and sends the information to Brandmeister's network. Anything coming back from Brandmeister goes through the same process in reverse.
Now, the bad news. The radio we have has such a horrible receiver in it, that it can't decode the data. So, we're forced to look for another radio.
Have a great day. :)
Patrick.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Hi Patrick -
I get that the modem can convert the radio audio to digital for feeding the internet connection. But a DMR radio uses TDMA modulation, time slots and a specific protocol. Will a standard FM transmitter work with the MMDVM modem to successfully transmit a compliant DMR signal?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hi Patrick -
While subscriber radios do rapidly key and unkey, DMR repeaters continuously transmit, even if only one timeslot is being used. Yes a FM transmitter will transmit a compliant DMR signal using a MMDVM modem. The only requirement is it is a FM transmitter and not a PM(lots of ham gear uses PM rather than FM) transmitter.
N0UUS
Iowa
Does anyone have a standard load for the uhf 450-480? I have a 2nd repeater that was tweaked to the ham band some and I want to bring it back. There was a table someone had earlier(not sure if it was a before or after), but I'm looking for this table for the stock version so I can at least get it back closer.
N0UUS
Iowa
Thanks.. I actually set them the same as my other UHF repeater and it seems to work fine, or close enough.
