WA Dept Of Transportation (P25 System) Updates
ww7ch
Pierce County, WA
I can not pick up the Everett site. I get no signal at all. I am just north of Everett. I can pick up the King County simulcast, King Lake site & Devils mountain Site just fine.
The site is located at WSDOT's facility on Chestnut between 20th and 21st streets, 7 or so blocks west of the Marine View Dr. onramp to SB I-5. Signal was strong when I passed by on the freeway last October. I presume you tried both the primary and secondary CC freqs for that site? Another site that I can pick up directly is showing this as a site on its neighbor list, so I can only assume that it's active and on the air.
cinsu
WT44
Southwest sites are starting to come online. Submitted the following
System ID: 040
WACN: C7D5A
RFSS: 221
Site ID: 221
License: WRCD942/WRAU590
Lat/Long: 45.58533 -122.19736
County: Skamania
NAC: 0DD
772.89375
773.06875 (Primary CC)
773.10625 (Alternate CC)
773.54375
774.38125
RFSS: 230
Site ID: 230
License: WRAS977
Lat/Long: 45.59194 -122.43908
County: Clark
NAC: 0E6
770.31875 (Alternate CC)
771.59375 (Primary CC)
772.51875 (Alternate CC)
773.95625
774.45625
RFSS: 238
Site ID: 238
License: WRAU522
Site Name: Vancouver
Lat/Long: 45.65139 -122.66778
County: Clark
NAC: 0EE
769.76875
770.70625 (Primary CC)
771.86875 (Alternate CC)
774.80625
I'm on the Oregon side and typically have good range to Cowlitz, Skamania and Columbia County (Oregon) but no dice so far.
devicelab
Whacker Extraordinaire
Nowhere in WA
Randy any chance we could sort the WSDOT entries by Site # instead of SysID? It's worked out OK for the most part, but as you can see, it's going to get messy over time. I think most people would want to find a particular site, no?
RBMTS
There is no for us to assign any type of sort factor when it comes to SysID's and SiteID's. In this specific system, yes it will probably get a little wonky.
Edit: I should have added that this is the case when there is different SysID's. If there was only 1 SysID, the sort display would probably be different.
KE7TJK
S.E. Washington State
I find it interesting that there are no repeaters anywhere close to the south east : Yakima, Benton, Franklin, Adams, Walla walla. The P25 is completely dark here in the tri-cities.
Stay tuned. There are a number of new sites in EWA that are not live yet. Probably later this summer or early fall.
Scrutineer44
You can't say 'dragon' over the radio
SE Washington state, Tri-Cities
thanks... there are some new sites that have been turned on lately in SE WA, such as sunnyside, jump off joe, richland, prescott. I can see the repeaters on my scanner but I've never heard anything so far.
KE7TJK
They are still in the commissioning stages. There is some test traffic now, but full on testing will happen in a couple months with the intent on going live full time this fall.
code3kid
WA
Some quick research from the Spokane area. I’ll have to do some driving to get some more definitive answers.
Eastern WA area appears to be SysID of: 42
ScanYak
Eastern Washington
Here are a few I'm monitoring to see if some of the frequencies/info changes before submitting to data admins.
Sysid RFSS Site Name County Freqs
03E 92 (5C) 092 (5C) Beezley , Grant , 771.98125a 772.43125 773.18125c 773.43125
03E 93 (5D) 093 (5D) Beverly, Grant, 769.55625c 770.41875a
03E 106 (6A) 106 (6A) Saddle Mtn, Adams, 770.35625a 771.78125 772.55625 774.08125c 774.70625a
03E 110 (6E) 110 (6E) Goat Mtn, Okanogan , 770.35625a 771.78125c
03E 111 (6F) 111 (6F) Whiskey Dick, Kittitas 770.21875c 771.18125 771.84375a 772.80625
041 118 (76) 118 (76) ????????, Yakima, 769.69375c 770.16875a
041 127 (7F) 127 (7F) Lookout Point, Yakima, 769.59375 770.70625c 771.05625 771.60625a
041 137 (89) 137 (89) Yakima Ridge, Yakima , 769.66875c 770.06875 770.31875a 774.68125
041 220 (DC) 220 (DC) Bickleton Ridge, Klickitat , 769.31875a 770.01875a 771.93125c
Compiled using DSDPlus
tmfok7
Far Eastern Washington...
Here are a few more that I found.
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 041
System Name : WSDOT
WACN : C7D5A
Tower Number (Decimal): 119-119
Tower Number (Hex) : T7777
Tower Description : CLEMENS RIDGE-YAKIMA
Control Capabilities : Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Oct 29 11:53:36 2020
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00625,0.00625,30.00000,"Confirmed",0.01250,1
08,769.00625,0.00625,30.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0000","d",769.00625,"00-0000",799.00625,0,0
"00-0128","c",769.80625,"00-0128",799.80625,0,0
"00-0290","a",770.81875,"00-0290",800.81875,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
117117,"T7575",041,"00-0462",771.89375,""
118118,"T7676",041,"00-0186",770.16875,""
127127,"T7F7F",041,"00-0272",770.70625,""
128128,"T8080",041,"00-0268",770.68125,""
131131,"T8383",041,"00-0234",770.46875,""
137137,"T8989",041,"00-0106",769.66875,""
FileVersion:8
-TowerInfo
System ID : 041
System Name : WSDOT
WACN : C7D5A
Tower Number (Decimal): 124-124
Tower Number (Hex) : T7C7C
Tower Description : HANSENS RANCH-WALLA WALLA
Flavor : Phase 2
Call Sign(s) :
Timestamp : Mon Nov 2 10:34:59 2020
-Tables
-Frequencies
"00-0376","c",771.35625,"00-0376",801.35625,0,0
"00-0504","a",772.15625,"00-0504",802.15625,1,0
-Neighbors
121121,"T7979",041,"00-0520",772.25625,""
123123,"T7B7B",041,"00-0330",771.06875,""
125125,"T7D7D",041,"00-0072",769.45625,""
129129,"T8181",041,"00-0338",771.11875,""
130130,"T8282",041,"00-0216",770.35625,""
132132,"T8484",041,"00-0206",770.29375,""
135135,"T8787",041,"00-0308",770.93125,""
FileVersion:8
-TowerInfo
System ID : 041
System Name : WSDOT
WACN : C7D5A
Tower Number (Decimal): 128-128
Tower Number (Hex) : T8080
Tower Description : MANASTASH RIDGE-KITTATAS
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Thu Oct 29 11:32:56 2020
-Tables
-Frequencies
"00-0268","c",770.68125,"00-0268",800.68125,0,0
"00-0522","a",772.26875,"00-0522",802.26875,1,0
-Neighbors
9393,"T5D5D",03e,"00-0226",770.41875,"Unknown (Different System)"
100100,"T6464",03e,"00-0562",772.51875,"Unknown (Different System)"
119119,"T7777",041,"00-0128",769.80625,""
133133,"T8585",041,"00-0568",772.55625,""
tmfok7
Here are some more:
FileVersion:8
-TowerInfo
System ID : 042
System Name : System 042
WACN : C7D5A
Tower Number (Decimal): 178-178
Tower Number (Hex) : TB2B2
Tower Description : MAGNUSON BUTTE-LINCOLN
Flavor : Phase 2
Call Sign(s) :
Timestamp : Tue Mar 9 11:45:16 2021
-Tables
-Frequencies
"00-0228","a",770.43125,"00-0228",800.43125,0,0
"00-0416","c",771.60625,"00-0416",801.60625,0,0
-Neighbors
187187,"TBBBB",042,"00-0052",769.33125,"SPOKANE RHQ-SPOKANE"
FileVersion:8
-TowerInfo
System ID : 042
WACN : C7D5A
Tower Number (Decimal): 187-187
Tower Number (Hex) : TBBBB
Tower Description : SPOKANE RHQ-SPOKANE
Flavor : Phase 2
Call Sign(s) :
Timestamp : Tue Mar 9 11:40:29 2021
-Tables
-Frequencies
"00-0014","a",769.09375,"00-0014",799.09375,0,0
"00-0052","c",769.33125,"00-0052",799.33125,1,0
"00-0312","a",770.95625,"00-0312",800.95625,1,0
-Neighbors
178178,"TB2B2",042,"00-0416",771.60625,""
I am going to be looking for some more here soon...
RBMTS
I have added the new sites. It is also very clear now that the SysID's match the 6 DOT regions. As such I changed the names of the SysID's to match the region names. We'll see if this pattern remains the same.
code3kid
WA
I’m currently in Wenatchee and I’ve recorded a lot of routine traffic out here. Sounds like they’ve made the cutover.
60210 is the Wenatchee dispatcher.
60211 Sounds like the main operations talk group for the area. Heard some cool traffic during a avalanche control blasting operation on Steven’s Pass yesterday. As well as a lot of other typical unit-unit conversations.
Also heard a little traffic on 60201 and 60209
tmfok7
Went out Sunday since it was such a great day and did some radio searching and got this... I heard another tower but couldn't decode it well enough so will have to go hunt for it here soon.
FileVersion:8
-TowerInfo
System ID : 042
WACN : C7D5A
Tower Number (Decimal): 177-177
Tower Number (Hex) : TB1B1
Tower Description : LIND-ADAMS
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sun Apr 18 14:02:04 2021
-Tables
-Frequencies
"00-0336","c",771.10625,"00-0336",801.10625,0,0
"00-0470","a",771.94375,"00-0470",801.94375,0,0
-Neighbors
106106,"T6A6A",03e,"00-0812",774.08125,"Unknown (Different System)"
121121,"T7979",041,"00-0520",772.25625,"Unknown (Different System)"
130130,"T8282",041,"00-0216",770.35625,"Unknown (Different System)"
174174,"TAEAE",041,"00-0676",773.23125,"Unknown (Different System)"
