What is the reason for the "i" in front? Is it something the older scanners need?You can add RIDs along with what unit they are. When entering them just put an i in front of the number.
When you enter the uids, do they need to be separated by county? Assuming it's a Statewide system, and you are adding uids for multiple counties, or can you enter everything under the name of the state system? I am wanting to use NC VIPER and add uids for several counties. For example:Chowan and Perquimans often back each other on calls and use the other counties talkgroups. I am trying to not duplicate the uids. Thank you
Regards Richard
Back in the 80's when the PD I was with when we wanted to have a private call to another specific radio we placed an "I call" meaning a call to an individual radio. My memory is you iniated the call by placing an "i" and then a 6 number identifier for the radio you wanted to call. Such as "i123456"I believe that the "i" is needed for scanners that do NOT have SD cards/programmed by Sentinel. This was a feature added later on to the x96 model scanners.
The purpose of a UID is to let you know who (specific unit) that is talking. You'll have to build your own table on what UID equates to what unit, unless you are fortunate to have someone do the work and is shared, such as the VIPER system.
What am I missing here? When I try to enter an "i" in front of a UID in Sentinel I get an error "Over The Limit" and not valid.
