Sentinel: What is the best way to update my current programmed systems without altering anything else?
Unidener
ENC
Imported with Proscan is not the same as reading the scanner as some think.
The favorites lists need to be created by using Proscan to connect to the Radio Reference database, selecting the system, and importing it that way.
When imported correctly, RRDB Differences will appear next to the system like shown here.
Yes.....I get those......
I was just wondering today how to check for updates so I could check the above like I've done before....but before I just happened upon it and today I was wonder how to have ProScan check RR for differences......
dave3825
Suffolk County NY
If the system was created in the fav list by the method I posted above, the rrdb differences button will appear next to the system. Not next to the heading of system, like in your screenshot. When it’s shows next to the system, you would click it and on the window that opens, you click get data and it displays the differences between what’s in your scanner, what’s in Proscan, and what’s listed on radio reference.
Unidener
ENC
I've been using ProScan for years....I just got the SDS100 and created my FL.....I've seen the RRDB differences that I posted the pic of but now 2 of you have mentioned RRDG Differences BUTTON.....
I have not and have never seen this button, can someone send me a pic please?
Well I just realized I was using version 17 of the Manual :rolleyes:
It shows 1751482846760.png but it does not show enough of the screen so I can see where to find this......IT CAN'T BE THIS HARD
jtwalker
It shows View attachment 186157 but it does not show enough of the screen so I can see where to find this......IT CAN'T BE THIS HARD
Post 11 and post 20. You still don't specify "how you created your FL in ProScan". It matters.
Unidener
ENC
After and read/write now I get this but I don't get the picture above "location of the......
Now I can press the RRDB buttone and get the boxes
Unidener
ENC
Just an update.....got on RR today and check and the RRDB Differences button is there and still works w/o are read/write.....
I was using 23.5 so I don't know why I had this issue but it does appear that IF not there, try a Read/Write......
Oh well all is good....have a great and SAFE 4th of July weekend!
dave3825
Suffolk County NY
Go check the last couple pages in the Proscan software thread. Believe there may have been changes between 23.5 and 24 regarding rrdb differences. Use to write a file rrdb.txt and believe newer writes to fav list and eliminates the txt file. When I upgraded to 24 I lost some stuff.
Unidener
ENC
Yes....24 did seem to have some problems.....it would intermittently hang when changing tasks.....I did (as always with ProScan) just install it like an upgrade. I was going to copy data and uninstall then try 24 again.....But the other day, when trying to get the RRDB Differences, I just installed it......it's been running fine since....and like I said today.....RRDB Differences is back and working.....
I love ProScan!
Still have some spreadsheets from manually entering names and frequencies:rolleyes: That's why I built Gorden's interface for my 2006 so I could program through the PC.....the good ol days......but I like this new stuff better!!
Have a great and Safe Weekend!!
