Added spectrum survey mode.
Edit FMP24.SurveyList to define centers of 2.4 MHz spectrum chunks.
Typically, centers are multiples of 1 MHz and spaced 2 MHz apart, for example: 770, 772, 774.
Chunks do not have to be contiguous. Example: 451, 453, 455, 461, 463, 465.
Set an appropriate gain level before starting a survey.
Press 'Y' to start spectrum survey.
FMP24 will continuously sample the spectrum chunks defined in FMP24.SurveyList.
For fastest operation, FFT size should be set to 16 in FMP24.cfg before starting FMP24.
Spectrum data is written to .survey files.
Use Survey.exe to view spectrum history.
Press Esc to stop a spectrum survey.
Survey 1.5
FMP24 Spectrum Survey Viewer
This program continuously reads the .survey files created by FMP24 during a spectrum survey.
Two windows are displayed. The first shows the peak and average levels for a 2.4 MHz chunk
of spectrum. The second shows a frequency vs time 3D display of the same 2.4 MHz chunk.
Edit Survey.cfg to set the height of the 3D display.
Edit Survey.cfg to set .CSV frequency data file names.
Edit Survey.cfg to set monitoring location and frequency data search distance.
Pressing '?' lists all active keys in the console window.
Use the left and right arrows to move to spectrum chunks.
Press [ or ] to select an appropriate step size.
Mouse over the first window to display license data.
Press PageUp/PageDown to move the mouse in fine increments over the first window;
this makes it easier to place the red mouse line on carrier centers to trigger the
license information display.
As the mouse line is moved across the first window, the corresponding spectrum
in the 3D display is highlighted. Press 'I' to isolate the highlighted spectrum
if it is hidden behind stronger signals.
To delete old survey data, delete all .survey files.
