I like where you are going !..
The chan selector uses a white lamp however it passes threw 2 filters.
From memory the first filter is amber the second filter with the numbers is orange, or is it the other way around ? hmmm
So I don't think the green will pass threw very well and the red may wash out...
However The signal meter ( on the cheetah ) uses a lamp with a yellow filter for RX and switches to another lamp with a red filter for TX. If the meter were to change to green for the second bank I think that would look awesome...Even better on the samba !!
I recently replaced the chan selector in my D858 Madison. This got me thinking .... All D858 SSB radios have the same code. I thought what if I acquired another switch with LED readout and mounted it externally of the radio in its own box.( like the Digiscan ) This would leave the cosmetics untouched and add a modern touch with full 40 channels no gaps ( except the Alpha gaps ) As I am only using this radio as a home unit the remote/satellite chan selector is not an issue...
But yes I do like your idea and am interested !!
Orbieswar
If you want, you are welcome to the mod I am going to do to the Simba. I already tested the dual color LED idea last night. I use a Red/Green LED to produce yellow and green. When it is yellow, the channel indicated looks like the stock amber color, and when it is green, the channel indicated is green. My plan is to drive the LED and the 858 with a 28 pin PIC microcontroller like in the video. I will intercept the 10 wires coming from the channel selector and have 10 replacement lines coming from the PIC going to the 858. If you pay for the parts (about 5 bucks) and the shipping, I'll program the part for you. This assumes I get the Simba working, since the ebay ad says it is not.
tink
