majoco
Stirrer
Back in the late 70's I had a job with the NZ CAA installing crystals into Redifon R499 receivers which were going to be used on the South Pacific HF MWARA frequencies - I don't know if we supplied Tahiti but we did supply Fiji, Tonga and the Cook Islands as well as NZ of course. I believe that now the stations are supplied with Cubic and Marconi equipment so all those R499's became surplus and I have one. It's complete with the front end coil packs but no crystals - so my question is - where did all the crystals go? I know the radio works because with a bit of fiddling I injected the right frequency from a sig gen and I could hear signals, but I think the sig gen doesn't have the grunt to make it work well. The most useful frequencies around here are 13261kHz, 8867kHz and 5643kHz which means I would like to find crystals of 14661, 10267, and 7043kHz - the IF is 1400kHz. If anyone with a selection of HC6u crystals with the 12.7mm pin spacing - not wire leads - could they please have a hunt through and see if you can find one or two or three! I will gladly pay all your expenses - thanks in advance.
