I'm not at all the miserable type. I don't understand how you came to that conclusion.
Let me draw the lines:
Voyager said:
Some people are just miserable, and can only feel better by trying to make everyone else miserable, too.
Some are disgusted because they don't know the scanner, and refuse to learn how to use it. They think scanner knowledge should just "come to them" and want instant gratification. Then, they end up being the above type.
The "above type" refers to the type described in the first paragraph.
You replied to that quote that:
To my defense(since I'm lumped in with "the above type"),
Now, if that was a misunderstanding, so be it. You don't seem like "the above type" to me. You appear to be the type who post issues without the criticism that others have - such as saying Uniden should die. And THAT is how issues are resolved - not with baseless accusations.
Yes, are correct. I now remember that coming up once or twice before. Just one of many times that memory has failed me. I heard it gets worse with age...
I heat that.
I don't buy the "it's the system" defense either.
Please note I said "might" be the system. I wasn't saying it definitively was.
It was posted in another thread that some systems are intentionally mistuned to lessen the effectiveness of scanners. I'm not debating the merits of that statement - I'm only passing along that the statement was made by someone who has a "problem system" in their area. It's plausible, albeit perhaps unprofessional.
The reason being is because I have two linux computers running OP25(one laptop to move about the house and outside) set up to decode this troublesome system. It does not matter one bit where the antenna is located, I get excellent copy of all transmission and no missed calls or drop-outs. There are occasional blips, but more often then not, the SU is asked to repeat their transmission.
I would bet most any modern PC has more processing power than a scanner, so it's a bit like comparing applies and oranges. The PC can sample the waveform at a much higher rate and compensate for anomalies.
BTW, your last statement proves that the system can be responsible for some issues, but I'm not going to harp on that.
I did admit that I believe the hardware could be better, and the result of your statement proves that. But, how reasonable is it to design such capability into a scanner? Again, design is about compromise to meet a certain price point.
Well, ten years ago I might have agreed with you. But here we are today, with the same basic design they've always used.\
<snip>
Meanwhile, I'm enjoying the hell out of SDR stuff.
I agree that the design could be better, and I don't know how much it would take to change the design. The return has to cover the expense.
As for the current generation, it handles my local LSM system fine - about equal to my XTSs. That proves to me that it CAN work well. Maybe it takes more work than the PC/SDR combo, but SDRs can do a LOT that scanners cannot dream of doing.
As for enjoying SDRs, 100000% agreed. They are wonderful devices - even the cheap ones that have their own issues (granted, they were never designed to do what they are doing).
