Which Baofeng or Wouxon would make the best scanner
scanmanmi
Central Michigan
I am interested in maybe getting one of these ham radios to double as a scanner. It's difficult to find out certain info about them.. What is the scan rate? Squelch tails really piss me off when set to tone squelch.
n5ims
Neither are really good scanners. It's not what they're designed to do. They scan very slowly (about 10% of the rate of scanners), which is fine for scanning the typical lightly used ham repeaters, but you'll miss lots of action scanning the typical large city conventional radio channels that are heavily used. Also, it will not do any type of trunking nor will they handle any digital signals.
If your main goal is to have a ham HT that will occasionally be used to monitor some conventional frequencies, they'll do the job OK. If your main goal is to have a scanner that will also work as a ham HT, you'll be sorely disappointed. Be aware, that this advice isn't just for the cheap Chinese HTs, but for all ham HTs that have extended range receivers.
ko6jw_2
Santa Ynez, CA
A dedicated scanner will out perform a ham radio HT in many respects. It's easier to select banks or systems and to do basic things like locking out a channel. Scanners are also designed to receive trunked systems and digital signals. No HT can do that. On the other hand, if you want to monitor a few channels and have the benefit of a professional receiver, then an HT is fine. I use mine to monitor the local fire departments and USFS. All conventional channels. A final point to consider is that scanners, while not as sensitive as ham or commercial radio, will offer better sensitivity outside the ham bands. Example, several of my Yaesu HT's can receive the CHP at 42Mhz, but my scanner is much more sensitive. Finally I have read reviews and heard comments that the receivers in the Chinese HT's are not nearly as good as they should be in terms of intermod and overloading.
RobKB1FJR
Lexington, NC
I use my Baofeng UV-5R+ in TDR mode. A is my town UHF Police, B is my Town UHF Fire. It works similar to priority mode in a scanner.
It would not make a good scanner for reasons mentioned above it is slow. If you have maybe 2 or 3 channels to monitor In a small town it would work just fine. Just be sure to use the baofeng or chirp software to prevent accidental transmit on the public safety frequencies.
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
+1
Kind of like using a Chevy Spark in a NASCAR race. It will go around the race track like the professional race car will, but that's not what it's designed for.
