Which County?
buddycrystal
I live in Benton County and use a BCD996t. Besides Benton County, which neighboring county should I also monitor? Thanks in advance.
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
FWIW neighboring Washington County has mode "D" (FDMA) talkgroups which the OP should be able to bring in with a BCD996T with exception of mode "DE" which are fully encrypted. Carroll County Sheriff is FDMA as well on the same system
k5kvn
NW Arkansas
Generally, I suggest also monitoring Washington County entities. Benton and Washington County police and fire often offer mutual aid and cross county lines in pursuits, etc., especially with I-49 traversing both counties. As mentioned above, it depends on what systems (P25 Phase 2, etc.) your scanner will receive/decode. I don’t often hear other neighboring counties in AR or OK doing much together. But depending on your location, you might hear Madison or Delaware counties.
Starcom21
IL /MO/Global DB Adm!n
The only good answer is: The ones you want to listen to.
