- Joined
- Dec 2, 2015
- Messages
- 23
I'm looking for a cross-band repeat capable VHF/UHF (or quad-band) analog mobile to mount near my attic antenna while I use my handheld around the house/property (on UHF). Price is a consideration but could pay for quality - or at least up to ~$400 - if I was confident it would serve my needs. That said, there are a number of options in the $200-$250 range...
Both the TYT's can be purchased for under $250 with programming cable, separation kit, and any other helpful accessories.
I would happily purchase a good Japanese radio but Yaesu and Kenwood have discontinued analog cross-band repeat mobiles except for the $400-$600 digital-capable models. And the secondary market is not cheap. The ICOM IC-2730A remains but I have no experience with ICOM and I'm a little turned off that they sell a bare bones radio with all accessories having to be purchased separately.
Finally, it's an absolute MUST that these radios work well MARS-modded. Don't need explanations or debate and I'm aware all these radios can be modded. But again, I know the TYT functions well MARS-modded (like my Yaesu single-bands). If the Alinco, Anytone, or ICOM have problems on MARS frequencies, that would be a deal-killer.
If none of the above are recommends, I'll just cobble together a cross-band repeater using two of my quality Japanese single band units and a cheap controller. But would prefer the ease of a single radio with a single antenna and coax run.
- I currently use a TYT TH-9800D Quad Band in my truck and it's a decent radio BUT the delay between RX and cross-band repeat TX is annoyingly long (apparently the template for this radio, the Yaesu 8900, discont'd, had the same problem). It is also very sensitive to near-frequency signals and the squelch will open randomly when using a good antenna.
- I'm considering a TYT TH-7900 Dual Band (successor to the TH-7800 and Yaesu 8800 copy) at roughly the same price but suspect it will have the same problems.
- So, would the Alinco DR-735T have better hand-over from RX to TX in cross-band repeat than the TYT models? Better selectivity? It would cost me more than $150+ over another TYT.
- Is the Anytone AT-5888UV any better than the TYT's? It's roughly the same cost as the TYT's but not a known quantity to me.
- How about an ICOM IC-2730A? This would cost roughly double another TYT once I have a programming cable and accessories.
- Any other models I should consider?
