Whistler 1040. Will not scan trunking freq. HELP before I throw out window.
captwilly1127
Mine also just started not scanning trunk group. i re loaded the v scanner file with same result. very weird as it is only 3 days old now.
tvengr
Well Known Member
Baltimore County, MD
Robbins and Vass are a good distance apart. Do you have both sites in Moore County programmed? What programming software are you using? The Carthage site is much closer to Robbins.
1 (1)011 (B)CarthageMoore, NC851.275851.600851.975852.550852.950853.1125853.325
853.675a855.5375c
1 (1)054 (36)Southern PinesMoore, NC769.25625769.78125771.38125771.63125772.23125772.85625773.15625a
774.18125c
crippledchicken
Butler County MO
Mine started doing that also, and the T stopped flashing at the top. I did a total reset on the scanner and wrote my scan list back on it again. It started picking up all the local P25 traffic but, rarely picks up the other counties that it picked up nice and strong before. I've heard the ws1065s were prone to this problem because of the eeprom memory starting to fail. I went ahead and ordered a couple eeprom chips and replaced it but, it's still the same. I guess for $1.36 each, it was worth the try but I sure don't miss working with those tiny smd devices! :LOL:
StoliRaz
I remember years ago I owned a RadioShack PRO-164 that stopped trunking like that as well. I ended up selling it as is. Yet its twin, my PSR-300 has been working flawlessly for the past 10 years. Guess it's all luck of the drawer
