Since first genration P25 and standard narrow band FM are 12.5 KHZ. what do you do for the conflicting channel spacing? The codec has been a topic of several ham groups. If the codec where open as well then maybe folks could build there own circuit or chip or develope thier own codec.
Open Codec or Closed, it doesn't matter, since you can purchase the AMBE Codec chips to make "subscriber" radios, and Analog to Digital Bridges.
Secondly having a repeater that is backward compatible does not leave the anolog user out in the cold who may not have to money to upgrade to a new digital radio. DSTAR repeaters do not give an anolog user that option.
1: D-Star actually has a section of the protocol specification that details how to link a pure analog repeater into the digital side of things
2: Just because Icom chose not to build their D-Star repeater so that both modes could use it doesn't mean that it's not possible to do; there are numerous (no, I don't have an exact count to give you) homebrewed D-Star repeaters that are configured as dual-mode repeaters.
With that being said I think that it does make one digital format more flexible than others. I like the project 25 repeaters personally I currently use because I can operate with a Anolog or P25 Radio on the same repeater. The P25 repeater (Motorola Quantar) can sense what type of signal it is recieving and change modes automatically. I believe the new Yaesu Fusion repeaters that use their new format have the same backward compatiblity abilty.
As I said above, this is possible if the builder of a homebrew D-Star repeater chooses to do so; not all do, for various reasons.
I am aware that DSTAR machines along with the New Yaesu Fusions can be networked. If I understand correctly the orginal P25 repeaters do not have linking capabilty by design. I did hear there is a group in Hawaii that have devloped a way of connecting P25 repeaters with VOIP. It will be interesting to see how the Ham Radio community drives the implementation of digital.
If you could get past your apparent anti-Icom bias, you would see that D-Star has already done quite well over the almost 10 years it's been around with at least as many homebrew systems on the air as there are Icom systems.
