I would suggest the Radio Shack antenna outdoors FIRST. Depending upon weather in your area right now, doing anything outdoors could be difficult in the cold. Even though that antenna is multi band, it's design will most likely do a better job than the coax constructed antenna because of the lower radials on the 20-176 acting as a ground plane, more so than the coaxial antenna. One of the reasons that the 20-176 may not work inside your attic as well as you want it to is that some construction companies have used a metallic underliner under some roof installations and that underliner, if used in your residence, could effectively block some of the RF energy getting to the antenna indoors. Moving it outside will most likely do a better job for you. If I remember correctly, your antenna has a vertical element and two additional elements at a slight upward angle. Position that antenna so that series of vertical radials in perpendicular to the transmitter location that you are most eager to receive. It is an omni-directional antenna, but placing it's profile 90 degrees to the station MAY increase the signal to noise ratio for that distant station and allow a better chance of reception.
