WIN500/APCO25 program question
rickster51
rickster51
I have been using WIN500 ..... since JANUARY I have noticed I am not hearing what I have been hearing in the past . Is there something in the APCO25 that has changed . In the past I picked my towers and entered the control frequency for that tower . Recently here I have noticed a DEC and a HEX for the tower.... and it seems as though one tower serves a larger area . Do I program my WIN500 software differently now and if so what do I put where ? Or is the programming ok the way it was ?
rickster51
rickster51
oops .....MPSCS ... N W Michigan ... most of the area police.fire &ems agencies are on APCO25 . AND I used to hear them ALL ....but the past , say 90 days I only hear some local traffic ..... and NO it is NOT digital encryption via apco25
mule1075
Washington Pennsylvania
Double check and make sure that the control channel did not change. That is the only thing I can think of. Maybe someone else will chime in.
rickster51
rickster51
I thought of that ..when I came here to check them I noticed NOT as many towers ...then I seen a dec and hex for the towers ,BOINK !!! Which I do NOT recall seeing a while back when I was checking the info and all the stuff was running as normal ...... last 90 days has been real quiet and I am NOT hearing things and places I had heard in the past . So I am a bit baffled at this point . And I have an old GRE PSR500 and a fairly new WS1040 .... both programmed via win500 , same programming .
mule1075
Dec and Hex should not make a difference. Might want to click on the read triangle and get this thread moved to your state forum.
mule1075
Should have been red. I hate auto correct.Right hand corner by your join date. Click it and ask for this thread to be moved.
rickster51
rickster51
OH MY ... I sent this in an email to Don Starr at win500 but got it back . Here is my problem in length .
I had a GRE PSR500 and programmed it with the WIN500 software ..worked fine ...till about 4 mths ago when I noticed it was NOT hearing objects I had been hearing for all the yrs I owned it . But I also had a battery issue with the psr 500 and now IT IS being used now exclusively in the house now .....so I bought a new Whistler WS1040 I programmed it with WIN500 and it too is NOT hearing what I had heard 4 plus mths back.
In my research on RR.com I noticed that the MPSCS list (I live in MICHIGAN) had changed . Where in the past (as recently as last summer ,2017), I had TOWERS with control frequencies and alternate freqs. that I entered into the WIN500(each tower site was then numbered IE 112 120 130 etc)) . BUT recently I also noticed that NOW ... there seems to be 1 tower per small area listed, that tower has NEIGHBOR SITES that are numbered ,no location (what maybe is the OLDER previously listed tower sites I used ). Seems to look as though mpscs took the most elevated site and it functions via the other neighbor towers in its area . Each main site is about a 20 mile radius as noted on RR.com . And they are now simply numbered 1 thru 5 if memory serves me correctly . HHHMMMMM now with looking at the RR.com mpscs info ...the TOWERS listed with 1 thru 5 now have a HEX and a DEC number associated to that tower and NOT control/Alt freqs ...the neighbor sites are just a number (IE 420 312 265 , etc no control/alt freqs)...... in the past the talk group I programmed had a hex and dec(and still does) , the TOWER sites ,back then ,all had freqs listed (so this really shortened the list now ) ?????? In the WIN500 program (yes mine is the latest v2.08) I see the system list where my control/alt freqs go ..... BUT WHAT about the new HEX DEC numbers for those TOWERS ? Where do those need to go ?
manlius
Hamilton, MI
If you go to this link....
http://www.radioreference.com/apps/db/?sid=100&tab=reports
....in the section right below the yellow box near the top you will see some “Pre-defined Report Downloads”. The first report listed is a spreadsheet version and the 3rd & 4th are pdf versions that have the site freqs.
I’m guessing you used the file titled “Site Location Data Report” under Other Reports.
When I first got my 436, I downloaded the 2nd file listed in the pre-defined section so I could re-sort all the talk groups numerically. Then I printed it out 2 sided and bound it in one of those plastic loomy binder things so as I traveled around the state with the radio searching for talk groups, I could look them up easily. That was when I was still learning how to use the radio and before I got the gps puck. Now when I travel I just load up the full database, Select the services I want to hear (usually just Police dispatch, tac and talk), set my desired listening range and go!
