win500-pro106
bryonh
Central City,IA
I just got a pro 106, downloaded win 500 updated the FTDI driver for my radio shack programming cable # 20-047. I make it far as fileSys-clone waiting start. Then the only option I see is cancel. If I click download from scanner all I get is timed out waiting for 67452 data bytes received 0. If I try to upload it tells me no response from scanner.
any help would be greatly appreciated. 73 Bryon KB0ZUA
DonS
Franktown, CO
I removed the cable and make it far as filesys-clone waiting start
What steps are you following when you try to download from the scanner?
Here's what you should be doing:
1. Plug 20-047 cable into USB port on computer and PC/IF jack on scanner
2. Turn scanner on
3. In Win500, select "Download from Scanner" on the "Scanner" menu
The red and green LEDs on the 20-047 cable should flash briefly, then the green LED should be on steadily as the scanner sends data.
bryonh
Central City,IA
2. Turn scanner on
Thank you Don I think I got it now. win 500 can communicate with my scanner
