Windows 7 SP 1 Error
Saint
Fort Erie Ontario Canada
Service Pack Failed to install
:confused:Just tried to Install Service Pack 1 for the fourth time, this time I tried to install the service pack 1 in (SAFE MODE) but again it failed to install again
UNSPECIFIED ERROR
ERROR E_FAIL (0X8004005
Failure configuring service pack 1
Steve
bpsmicro
near Ottawa; Canada
While it may not be relevant to your issue, just in case make sure you're running the SP1 installer as Administrator (not just logged in as an administrator, actually "Run as Administrator").
Also, check free space on your disk. It's a huge update, that'll expand to a local folder as part of the install, so you want upwards of 2Gig free.
Brad.
Saint
Service Pack 1 Failed
Brad.
Thanks for the suggestion Brad but I just tried it and it also failed to install the Service Pack Again, I have tried SIX Times now with no luck.
Steve
n0nhp
Grand Junction
After hitting retry about a dozen times, I finally got past the 18% and am now on SP1. I decided to just be hard-headed about it and keep trying till it worked.
Bruce
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
:confused:I have already downloaded it to my computer !
I'm trying to install the service pack 1 onto my computer
Steve
I've installed it about 5 times so far without any issues. Have you tried disabling or uninstalling your AV software first? Might also want to to try using CCleaner to do a quick cleanup and registry scan before the install.
Saint
Install problems
Thanks Mike I did all of those things and more, I have tried to install The Service Pack 1 Twelve (12) times now and have had no luck at all, the only thing I can think of doing now is to re-format my harddrive and re-install my Operating System and then re-install All my programs. It's A job that will take a good day so I don't have the time right now to do it so I will put it off for several days.
Steve
mike_s104
Steve
what error do you receive? anything else running in the background?
Saint
Service Failed
this is the error
UNSPECIFIED ERROR
Nothing running in background I even tried in SAFE MODE
Steve
mike_s104
this is the error
UNSPECIFIED ERROR
Steve
I found the below. You probably have something more wrong with your PC that not able to install SP1. I would, if I were in your situation, backup my data and reinstall Win7. As soon you are done with the install and drivers, I would do SP1 then any other updates. I would hold off any AV software install until your done with SP1 an updates.
ERROR E_FAIL (0X8004005) while installing Service Pack 1 for Windows 7 (I know the link says Vista but it is for Win7)
Saint
FAILED Installed
Yep I agree with you, I will be re-installing Windows 7 and reformatting my harddrive again from scratch to fix the problem.
Steve
soberbyker
Delaware County, PA
Brad.
Also remember to keep auto update on, for those that didn't the SP1 update is like 800mb where as those that did regularly update only have about 80mb to download.
A little too late now but words of wisdom here from Astrak, most of Win7 SP1 is updates that have already been released and as such people who have kept up on the updates have very little to download and install. I took care of it yesterday on mine, just a few minutes involved.
This looks like your exact problem here, see post #2
Saint
that's my post
Steve
soberbyker
Delaware County, PA
that's my post
Steve
Small world huh, I guess it would be exact then. Didn't connect the two screen names, until just now.
Seems like you're set on reformatting, a pretty drastic move. Do you have a Windows 7 disk and key? If so try reinstalling it over itself, you'd lose personalize settings but keep your documents, photo's whatever. There may be a repair selection on the disk as well.
Saint
re-install
Seems like your set on reformatting, a pretty drastic move. Do you have a Windows 7 disk and key? If so try reinstalling it over itself, you'd lose personalize settings but keep your documents, photo's whatever. There may be a repair selection on the disk as well.
I have the Windows 7 disk and it's key, when I get some time I will do it.
Steve
soberbyker
Delaware County, PA
You said you have Microsoft Security Essentials, are the definitions up to date? I run that too and updated it before running the SP1 update. When I did my update I did not turn off Microsoft Security Essentials and didn't have any problems.
mike_s104
Steve
You should make an image once you have Win7 installed and SP1 installed. I would suggest Drive Image XL (Free) or Macrium Reflect (not free but I used it and bought the 3 license version). That way, if something ever happens again, you can just reimage and it will take only about 15 mins or so to have your PC back to where you want it. I used Macrium Reflect to make an entire image of the domain controller at home and my PC (would do the wife's but she has too much crap on her laptop and I just save everything to the server) every other day saving 3 image versions each.
