Wireless Mic PMMN4096B
jokster
Massapequa, NY
I have Motorola wireless mic model PMMN4096B, I am trying to pair with my APX 8000, it pairs but only has receive, cannot get it to transmit. Not sure it is a firmware issue. I had it orignnally paired with my XPR 7550. Any help would be great.
hill
Middle River, MD
Don't think it can pair with APX8000
Says it only works with XPR radios.
The only APX it will work with is APX900. Guess with this radio being lower tiered.
K2NEC
5F6
Under Radio Wide>Bluetooth, what do you have Bluetooth Pairing Type set to?
KE4ZNR
Radio Geek
I believe this is accurate. You need the PMMN4095 if you want to pair to an APX portable like the 8000.
I have the PMMN4095 and it works with my 8000XE no problem.
KD9FAL
I have had the PMMN4096 Operations Critical Wireless Mic paired with both an APX6000 and APX7000, so it would lead me to believe that it will pair with an APX8000.
From the users end point, the only difference between the two mics (PMMN4096 Operations Critical and the PMMN4095 Mission Critical) is the blue dot pairing.
