Wiring Problems
Nebraska
Hello. I've had a CB in my truck for almost a year now. I originally had it wired in to the fuse box which worked great until I started to get alternator whine. I then wired it directly to the battery, which got rid of the whine but brought on some other problems. My radio works fine when I'm stopped bur for some reason, my radio is extremely quiet when I'm moving. Even with the volume maxed out, I can barely hear anything coming through the radio. I can't seem to figure out why.
jonwienke
More Info Coming Soon!
VA
Do you mean engine off/engine on, or moving/not moving?
Nebraska
jonwienke It's when I'm driving, the faster I'm driving, the quieter my radio is.
W5PKY I have a 2004 silverado. My antenna is a 4 foot Firestik mounted in my bed.
R
retiredmich
Guest
On your alternator, put a ground wire from your alternator to your truck frame.
Project25_MASTR
Millennial Graying OBT Guy
Texas
I'd almost say look at the antenna and mount. The faster you go, the quieter it gets. Almost sounds like something is disconnecting from wind load (a break in the antenna or where it connects to the coax).
Nebraska
I went out and cleaned all of the connections and checked everything else out. It seems to be in working order now but I won't know for sure until I get back on the interstate. Thanks for the help everybody!
