Programming the new wiscom freq problem.
getting ready to program the new freqs into my BC796d and it says there are base channels to also add, but on the RR wiscom site it only lists control channels and nothing about other channels??
"Programming Type2/Digital VHF and UHF Systems
To program a Type 2/Digital VHF or UHF system, you need to know the frequencies the
system uses and also the Base, Space, and Offset settings. These settings are normally
provided along with the system frequencies.
1. Select the trunk programming mode.
2:SCAN OPTION → 2:TRUNK
2. Use the scroll bar to select the bank you want to program, then press E.
1:TRUNK TYPE → 1:ON
3. Select one of the following trunk types for Motorola Type 2 or digital Systems:
4:TYPE2/P25 UHF
Motorola Type 2 or Digital systems in the UHF (450 – 512 MHz) band
5:TYPE2/P25 VHF
Motorola Type 2 or Digital systems in the VHF (148 – 406 MHz) band
4. Set the Base, Space and Offset settings.
Note: Your BC796D allows you to enter up to three Base, Space, Offset configurations.
However, most systems only use one configuration.
a. Use the scroll bar to select the configuration to program, then press E.
BASE CONFIG 1
b. Enter the system’s base frequency, then press E.
c. Enter the system’s space frequency, then press E.
d. Enter the system’s channel offset, then press E.
Repeat a-d or press MENU three times to continue programming the system.
46"
