So apparently the Whistler WS-1080 does what the X36 does, maybe better. Anyone have one in Maryland? I'm thinking about grabbing one wi my refund (if any).
The WS1080 still has memory card issues and is not as sensitive as the 436. Get a Radio Shack 800MHZ antenna and a BNC to SMA adapter and it is the best handheld to date. I have tested these side by side. The 436 is a little quirky, but the better radio.
Jim
About 80% of SD card issues with any scanner that is SD card driven, are caused by user error, not a problem with the scanner. This includes Whistler, Uniden, GRE, and RS.
You should send it to Uniden.. I think they have a recall program for you problems..I have both, and would vote for the 1080. The clock on the 436,must be reset every time it losses power or is turned off and will not work until reset, my internal speaker no longer works, and I must use a powered speaker, the power connection does not always work.
Have you considered an HP-2?Any more opinions on the WS 1080?
My grandmother (84) scanner (PSR-500) has stopped working. She loves to listen to Anne Arundel Police. I am really debating on the best new scanner for her (definetly getting her a Phase II). I have mixed opinions on my BCD436hp. I will do all the programing for her so that won't be an issue.
thanks to all for input
iirc there was some concern that Whistler would be low-end, I guess not.
