XG-100P dead with batteries.
merlin
DN32su
I have an XG-100P that won't power on with batteries.
It does power on connected to a bench supply.
# batteries BKB191210/6 or equivalent all fully charged.
Anyone have this problem?
What is the fix?
TNX
KC8ONR
bridgeport
Did you check the voltage coming out of the battery? Just because a charger says its charged doesn't mean it is.
merlin
DN32su
Yes, all 3 will power P700pi just fine. It is like the battery contacts don't align with the pogo pins.
No continuity between the radio ground an negative charge button. Batteries are not bloated at all and measure about 7,8 volts on the contacts.
merlin
DN32su
Problem solved, the battery pogo pins had cold solder and the B- pin broke loose from the board.
I was hoping not to have to do surgery without a proper service manual but got the thing working.
Thanks people.
A caution: DO NOT USE an SMT heat gun, the covers on the board are thin as foil and will melt. Use a good iron.
