.xml File into APX CPS
jeffj31890
SmartZone and Omnilink đź“¶
SysID: 140
Hello, how do I add an XML codeplug file to APX CPS R36? It is for a trunking system and it generates which radio it is for.
Thank you.
WV8VFD
Batwing "File" button -> Import
Make sure system keys are loaded for the system before you do the import, or it will cause issues
WV8VFD
Make sure you're doing File>Import not File>Open and make sure the codeplug is already open in CPS
This. Full procedure would be
1. Read radio
2. Make sure system key is loaded
3. File -> Import
4. Select the .xml that you want to import
5. Check that everything imported properly.
6. Do your zone/channel assignments
7. Write radio
