XPR 2500 (R01.00.30) Update
RemixF
Connecticut
I am attempting to update an XPR 2500 I recently purchased, but am running into issues. I have both CPS1 and CPS2 installed, as well as all the firmware I could find for the radio from my Motorola Solutions account. The oldest firmware I was able to find was M2022.01 under MOTOTRBO NA Devices and R02.10.10 under MOTOTRBO NA Professional Devices. In CPS, I receive a message that "No matching package(s) exist". The radio is running R01.00.30. I believe I am missing some firmware which would let me update this radio to a newer version, but cannot find those versions online. CPS2, as expected, reports no firmware/codeplug (Unknown).
K2NEC
NA
What is the firmware package you installed? The 2500 has a different firmware package compared to any other TRBO
RemixF
Connecticut
Unless I am misunderstanding something, R02.10.10.0001. It's showing as NA XPR 2500 firmware R02.10.10.0001 under File Description. I am unable to find anything older than this build in the Software and Licensing area.
RemixF
Connecticut
that is ancient firmware. you can try to update it to 2.10 and use CPS2
Both CPS1 and CPS2 do not recognize 2.10, or anything slightly newer when I try and update this particular radio. I believe I need an older firmware, but those do not appear to be available in Customer Hub under Software and Licensing. This is my first time updating an XPR 2500, although I would've expected it to be the same process as the other stuff I've programmed/updated in the past (CM200D, CM300D, 3500e, R7, 5550e).
K2NEC
NA
RemixF
Connecticut
I installed MOTOTRBO_NA_2.05_R0210100001_150513_Mobile.exe. Running the latest CPS 2.151.292.0.
RadioGuy7268
PA
R 02.10 is what's going to be the highest you can go without purchasing a SUM from Motorola. SUM's cost money.
You would need to use CPS16 to bring your firmware up to something closer to R02.09.0001 before you could "Update" to R 02.10 using CPS 2.
"Update" is in quotes, because you would not necessarily be gaining any actual features or functions. What is it that you wish to gain by going through all the trouble to update?
Motorola will not assist with CPS 16, as it is no longer supported. Prior firmware packages that work with CPS 16 are no longer supported or available online through Motorola.
