XPR3500e No Bluetooth
N7AS
Prescott Valley, AZ
I followed the manual and could not find Bluetooth on the radio menu.
Is there a way to activate it in the CPS?
Tech21
Does bluetooth show as an option in "Configuration"?
If it does I believe it's under network options to enable it;.
hakwye8518
Town of Islip, NY
Bluetooth will be under the network tab. For a factory fresh codeplug 1st save your tuning data just in case. Next make sure you have either the same firmware thats in the radio or a newer version installed in cps and then do a recover.
N7AS
Prescott Valley, AZ
I am so fed up with Motorola. I got a NEW copy of MOTOTRBO CPS 2.0 latest version yesterday along with the 20/25khz bandwidth key.
I connected my Brand NEW XPR7550e and read the radio. I got as far as registering the key and then got an Error message for the next step. I had to call them back 5 or 6 times and still have not got it fixed. They outsource all the tech help to some foreign countries and am sick of listening to some dumbass foreigner try to tell me how to fix something when they know they don't know what they are talking about. I told them I want to talk to someone born in the USA that does not have a dumbass foreign accent. There are people in the US that need jobs. These companies are so cheap tightwad and don't want to pay someone who really needs a job.
I am done with Motorola and told them I am about to trash two NEW Motorola radios.
hakwye8518
Town of Islip, NY
You are registering the 20/25 khz bandwidth key as an application feature not a device feature correct?
Tech21
Dude, it's not Motorola's problem you don't know what you're doing.
These radios require some basic technical competence and unfortunately, you don't have any.
N7AS
Prescott Valley, AZ
CPS to reconize the 20/25 Khz key. I programmed some channels and when I went to write I got this error.
I got the same error when writing to write to my XPR3500e
Where do I go to fix this?
Tech21
General -->Security-->RAS key-->Type in 000000, then hit delete(minus symbol)
hakwye8518
Town of Islip, NY
In CPS 2.0 bottom left screen click on validation results and see what is wrong/missing from the codeplug and fix whatever the issue is.
N7AS
Prescott Valley, AZ
I have a problem with my XPR3500e.
I just have analog channels programmed. When I got the radio the company who had it went out of business and had some digital and analog channels programmed.
I got the same error message I had with my XPR7550e but when I went to look at the Validation Report this is what it showed.
Can anyone make sense out of this?
I still can't write to the radio.
hakwye8518
Town of Islip, NY
Under contacts make sure you have at least 1digital group call and 1 digital private call. It doesn’t matter what the ids are for that they just have to be there
