XPR3500e Programming
orgchemus
Littleton, CO
Good Morning-
I am programming my XPR3500e for my work frequencies; I'm very new to CPS and radio programming, but I want to learn.
To program this radio to work, do I need to create and assign a contact and a group list for each channel I create? For example, will I have 17 channels, each with a known department and frequency (Let's call them Shipping, Receiving, Production, Assembly, etc...), and an individual contact and an individual group list?
For Example:
Shipping: Contacts > Digital > Call1 (Contact)
Shipping: RX Group Lists > Digital > List1 (Group List)
Shipping: Channel > Zone1 > Channel1
Receiving: Contacts > Digital > Call2 (Contact)
Receiving: RX Group Lists > Digital > List2 (Group List)
Receiving: Channel > Zone1 > Channel2
Another question: Since each zone only allows 16 channels, for the 17th channel will I need a 2nd zone? I have 16 digital channels and 1 analogue channel. Will I select Zone 2 on the radio when needing to use Channel 17 or is there a way to have all channels accessible?
Hopefully I have described my situation clearly, and I can provide more information once I receive my programming cable and I can read a radio.
Thank you in advance!
Shawn
Floridarailfanning
Tennessee
No, you can use a single list for the first 15 contacts which can be applied to numerous channels. For the additional digital channels create a second list with the same contacts.
You should be able to put all of the channels in zone 1.
K2NEC
5F6
Everything sounds right but, I would put all of the contacts in the same group list. You can fit 16, make it count. It saves time and space.
There is no way on the 3500e for all channels to be accessible. Channel knob stops at 16 so you have to make a new zone for 17.
Floridarailfanning
Tennessee
Negative. CPS won't even let you put more than 16 channels in the zone. Need to create a new zone.
I've never used a 3500e before so I didn't realize it only has the 16 position knob, and just realized I had opened an SL3500e codeplug. :rolleyes:
Tech21
Yes, you have to create a contact for each channel and a rx group list for each channel.
orgchemus
Littleton, CO
Thank You for the update, and I used some of your advice. I have 2 Zones, setup identical but with different channels, but Zone 2 shows "Unprogrammed" after I select the Zone on the radio. I've looked at everything, read everything, but I have no clue what is going on.
Any help is greatly appreciated, and I create a link so you can view the codeplug. CPS 2.0
K2NEC
5F6
I havent taken a look at the codeplug but did you add a channel into zone 2?
N1GTL
CT
Unless I missed it, I did not see if you are using digital or analog. I'm assuming digital.
Unless I missed it, I did not see if you are using simplex, conventional digital repeater, IPSC, or Capacity Plus.
You DO NOT need a RX Group List unless you are you are using one of the trunking systems. RX GROUP is like a scan list for trunking systems. You add the additional talk groups that you want to hear besides the selected talk group. It is always on unless you select a FLEXIBLE RECEIVE LIST at which point you can turn it on and off. It is useful for always making sure you're monitor a specific channel regardless of the selected channel.
I would do something like this. Create your talk groups and ID's:
Shipping - 101
Receiving - 102
Production - 103
Assembly - 104
etc
Create your four channels and in the CONTACTS drop down, select each of the above and assign it to the channel. You CAN just leave a single TG and assign it to each channel as long as each channel is a different frequency/color code and/or time slot.
orgchemus
Littleton, CO
I did plus I figured everything out. I left maybe radio on Channel 16, but the 17th channel I needed was programmed in Zone 2, Channel 1.
Simple mistake but I was able to work through and fix my issue.
Thank You for all your help!
orgchemus
Littleton, CO
Good Morning Everyone-
I thought everything was good with my radio, but after trying to use the radio with my friends I'm still no good. Programming is okay: no voice, static, or anything is coming out of my radio ,but the two radios are communicating. Well, I think. When we are on the same channel and I press the PTT Button on my friends radio, my radio is flashing green. This happens on all channels, but no voice is coming through even though the radios are communicating.
I've double checked all programming, both radios, and I'm lost. Any help is greatly appreciated and I've uploaded both codeplugs. CPS V16 is the known working radio, and CPS 2.0 is my radio.
Floridarailfanning
Tennessee
OK, some obvious questions come to mind. Are you certain you set up the correct talkgroup ID's? If you just matched the talkgroup alias from the existing radio it's not going to work.
Also, does your employer know you're attempting to use their radio system? Legally you MUST have permission. Just being an employee is not sufficient, you need to ensure this is OK with your employer, plus they might have RAS setup on the repeaters which would prevent you from using the system anyway.
orgchemus
Littleton, CO
I think everything is programmed correctly, and I have permission. Will I not see RAS on the codeplug when I read the radio? It's a very simple setup simply talking between different radios, so it's something very basic I'm missing. Or I hope.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Do you have (or can you point me to) the codeplug that you read out of the work radio? Thank you, TT.
K2NEC
5F6
If you read a good working radio, the RAS key will not show up. It's a security issue. That way the normal person can't find a security feature of a radio system just by reading a radio. Chances are the only person that knows the key is the one that programmed the radios, ie. the radio company.
TampaTyron
Phoenix, AZ
The RAS key won't show, but all of the personalities (channels) will be tied to that RAS key. If you read it out of a radio, then the RAS value is now undefined and shows invalid. TT
TampaTyron
Phoenix, AZ
I could not find the original codeplug in your original post. I do see a codeplug labelled "current programming" in the 8th post of the thread, but the OneDrive link has expired. I would like to see the original codeplug before I open your codeplugs. TT
orgchemus
Littleton, CO
I'll have to add the files again, but the CPS v16 is the original file. I'll try tonight, if not I will in the am.
