XTL 2500 Power Cycling with antenna connected
zachzimmerman
Kokomo
Trying to save a XTL 2500 800 mhz from the grave. Unit runs great without an antenna, however when you connect an antenna to the unit, it goes into a power cycle loop. I have tried different cables; I'm out of ideas?? Anyone have any suggestions or ran into this issue?
zachzimmerman
Kokomo
It sounds like once the antenna is connected it receives a control channel and tries to register to a trunked system and the P/S can't handle the current draw.
I checked the numbers on my P/S, 2.5 Amp 12V Converter w/ 13.8 Volt DC 115V AC 50 Watt Power Input. Never ran across this issue before.
KevinC
Encryption
I'm everywhere Focker!
If it's attempting to transmit 2.5 amps won't be enough. I still stand by my it's trying to register to a trunked system.
Where did this radio come from?
zachzimmerman
Kokomo
Its a radio from a local fire department, that doesn't have much funding, so I am trying to get it back up and running for them. Let me throw it on another bench and see if that will fix the issue.
NVAGVUP
Better have it in a dummy load. If you are hooking it up to an antenna, this is classic radio registration/affiliation to a trunked system. System admins take great joy in bricking radios such as this. (And yes, your power supply is not capable of supplying enough current while radio is transmitting/aka registering to trunked system)
Yeah, grounding probably not the issue.
Current/voltage starvation, yes. If it's on a trunked system, it's going to try to connect, so it's going to transmit. A 2.5 amp power supply isn't going to cut it.
And I agree, connect it to a dummy load, you don't need to be annoying the trunked system like that for most of your testing.
ultrajv
You cant test those radios on a 2.5 amp psu. Your workshop or test facility dosnt seem set up for transceivers or RF. They are going in to transmit and rebooting due to lack of current.
zachzimmerman
Kokomo
Up and running, pick up a 30 amp test bench, no problems now. Thank you.
