ejboness
When attempting to read my XTL 2500 I get the message "Error Context: 24, Status: 80004005" I've gone in on the software and selected "USB" for the connection but still get the error.
Is this a REAL Motorola USB OEM XTL cable or some USB adapter with an Ebay special?
I used to have the same error code since I started using the USB Motorola cable, WinXP... Don't know why it appears, but in my situation disconnecting the cable from the PC and switching the radio off and then on again always does the trick."Error Context: 24, Status: 80004005" .
I'm trying to update the programming on an XTL5000 with an OEM USB cable. I've used the same cable, comptuer and CPS software version to program the same radio and it worked fine. I get the same message whe I try to read or write.
