XTS5000 Advanced System Keys and programming
Okay, I have a bit of an issue and done many days and hours of searching the interwebs and forums. I purchased another XTS5000 online that came from an auction. I read the radio, no problem. I go to program new things into it, and kicks back saying it cannot due to Advanced System Keys being present. I deleted the trunking system that was on it. I am wondering if this annoying issue can be solved through hex editor. I am a do-it-yourselfer and do not feel like shelling out the money to have this fixed by Moto. Plus, I don't get to learn in the process. I've programmed several of these, however this is the first I have run into this issue and it's an undesirable condition. I have the newest CPS, and hex editor. What can I do??
devicelab
Radio N.E.R.D
WA (USA)
Okay, I have a bit of an issue and done many days and hours of searching the interwebs and forums. I purchased another XTS5000 online that came from an auction. I read the radio, no problem. I go to program new things into it, and kicks back saying it cannot due to Advanced System Keys being present. What can I do??
I would return the radio personally especially if the seller didn't explicitly call this out in the ad. (The radio could be stolen for all you know.)
I haven't used it myself but my understanding is that the Motorola Astro Depot Tools software can revert XTS/XTL units back to factory states but I've never done it myself.
evfd1625
Indiana
There was a modified cpfix program in the wild that was a legit public released Motorola program that was designed to fix a switch issue but one of the database sources was modified to remove ASK/ACK problems. Might look around the Google's
I acquired the CPS legally for programming my junk. I don't know if messing with depot is something I want to do, as I don't want to brick this radio or run into problems down the line. The radio was bought off a fella that had a mix of different items. The one I bought was the only radio he had for sale. I let him know of the situation and he was willing to do a partial refund, which was nice. I checked to make sure it wasn't a stolen unit. I think I may break down and have it sent to a reputable shop to have it fixed and proper Flashcode put on it. Under $90 isn't bad I guess. I want to stay away from pirated or unlawful software. As always, replies are appreciated!
FFPM571
The Mid South
you don't need depot and a shop may not want to deal with it having an ASK CPfix is out there and works fine
Problem finally solved!
Okay, so after a while of playing with depot (which I didn't want because of reasons) I was able to create a new code plug, match the serial and model number and basically create the Flashcode (cloning my other XTS' flashcode that is confirmed working). I saved that code plug, opened it in the CPS, and it loaded right up. I then cloned over code plug from the other one to this one. No issues anymore. Problem solving at its finest. I can't wait to do my next one, honestly. Anyways, I couldn't locate the CPFIX tool. Hence why I broke down to depot. Thanks again for the responses!
Forgot to mention that the Flashcode options didn't allow for what I wanted. So that was problem number 2 solved.
