Yaesu: Yaesu VX-6 question
picscan
CA
I bought a Yaesu VX-6 and programmed CHP low band frequencies in to monitor and it will not pick up anything, tried everything. Any pointers? I know they're working on my scanners but nothing on the Yaesu.
rf_patriot200
Freeport, Illinois
I don't think Vhf low band reception is available in the Vx6 that I remember. 144-148, 222-225 and 430-450mhz. were the bands on that if I remember correctly.
sallen07
Rochester, NY
I don't have one, but it's advertised as having wide-band receive, and 30-76 MHz is one of the listed bands.
I'm sure the antenna isn't optimal for low-band though.
picscan
CA
Yes, I can monitor all frequencies, it does from 504 kHz-998.99 mHz. I did the mars mod to use FRS and GRMS too
picscan
CA
Specs say receive range is 0.500-999.000 MHz. I would bet your antenna isn't suited for lowband.
I'm using the same antenna as all my other radios. Everything else works fine, just not CHP low band. I just thought there might be something stupid I'm overlooking.
GlobalNorth
Fort Misery
Does the VX-6 tune to a very wide bandwidth, including VHF-Low Band? Yes.
If it suitable receiver for all bands received? No.
It is best suited for 144-148 MHz and 70 cm TX/RX and everything else falls away from there, in most uses. It does 1.25 meters, but not well. It is so lacking at that band, I bought a TH-D75 to cover that band,
picscan
CA
What model antenna are you using?
CHP whip mounted on the roof and a Diamond disco. All of my other scanners have no problem with the frequencies, I can get CHP 100 miles in every direction but can't get it on the VX-6, 2 miles away. I can get every band except 30-50 or whatever it's claiming.
cmjonesinc
Well that does sound odd. Right mode and bandwidth set?
picscan
CA
There is absolutely nothing coming out of that bandwidth, not a peep and I have three radios right next to it on the same channel with rubber duckies while the Yaesu is using the roof antennas. Yaesu helpful tech I called,....... "just because it says it'll receive that band doesn't mean it will". I guess I'll return it. It was part of the reason I bought it. I just wanted one call radio to carry and the sales guys were telling me it would do it all. Nice radio, just not for me.
W6VVM
I have a VX-6 and have two CHP freqs programmed in:
-Capistrano Green 1 Base 39.360
-Capistrano Green 1 Mobile 42.240
I don’t really listen to CHP but I am positive I have picked up traffic on 39.360 from the car, even with the stock rubber duck, granted VHF low on a rubber duck is pretty weak in the car. My VX-6 is stock (no MARS mod) and a fairly new unit purchased in the last year.
picscan
CA
Okay, found the problem.:oops: It was a brand new bad SMA to BNC connector combined with now clear skies that I hooked to my roof antennas, I am now reaching CHP
picscan
CA
It comes in even better when you put in the correct receive mode:ROFLMAO:, I didn't notice when I was scanning it would revert to AM instead of staying on NFM. I guess "auto" is default mode in each band. Really helps to read the manual. I reprogrammed the frequencies and saved in NFM and all is well.
picscan
CA
Another thing I found was I turned on attenuation and it cleaned up the signal 1000%. I guess with the roof antenna it was too much for it so now I just have to remember attenuation on for outside antennas and off for rubber duck.
radiotweester
Oregon
RX on everything else is fine? Depending on age there were bad 450kHz filter issues. Usually it affects all bands. Agreeing with W6VVM ducks on lowband SUCK. Even with a base antenna you don't have a lot of gain. If the scanner is receiving and with the same antenna the VX-6 isn't, it's probably worth a tuning.
