Zello error message. "Can't establish a secure connection"
KC1ART
Yarmouth, ME
This fixed both login problems. Now let's just hope Zello people won't see this post and block this workaround.
Neat, I’ll have to try it out. My only issue, I’ve already got TwoToneDetect using port 8080. Is it as easy as changing to a different port in the MITM settings?
Fireman-Sam
Yes you can specify port in command line, for example "mitmproxy.exe -p 5555". You will see the listening port in the bottom right corner of the console. Remember to set the same port in Zello and add parameter p- 5555 in Windows Task for automatic start at Windows startup. See below screenshots. Note I didn't have time to test the task parameter (last screenshot). Please report back if it works.
txdaredvl
Texas
Hi guys, I found a solution that enables full Zello legacy app functionality as before (Enable TLS and Sign-in when Zello starts).
Just follow these two steps:
1. Install mitmproxy (mitmproxy - an interactive HTTPS proxy). You do not need to configure anything, the default configuration is OK. Just run mitmproxy from start menu or from C:\Program Files\mitmproxy\bin\mitmproxy.exe if you have disabled script execution.
2. Set Zello connection settings as in the screenshot below:
Now you will be able to normally login. When you confirm everything works, you can set mitmproxy to autorun with Windows and without the console. Just create Windows Task that runs mitmproxy.exe as SYSTEM on startup:
View attachment 187429View attachment 187430
txdaredvl
Texas
As it looks like the legacy app has now been closed off. Both of my computers won't log in at all with the legacy app. (Different accounts). Can any confirm if this set up is working today. I got one of my accounts on using bluestack but would love to get both on if this method hasn't been blocked by zello today.
nosoup4u
High Bridge, NJ
May I ask what the point of doing this is? You are still sending unencrypted traffic over the internet to zello. As long as you can disable TLS in the client, you are not really solving anything here other than being able to click the check box. This
I found mine was not working, so I shut it down and restarted it and is working again
txdaredvl
Texas
Will do a pc restart and try it. As I closed mine and tried it still failed. Wonder if the work around above will keep it going after the August deadline.
Edit. The computer had 2 instances of it running. Not sure how that happened. So even though I exited I guess the other running didnt allow it to actually exit.
Fireman-Sam
For users that are unable to upgrade legacy app, Zello suggested disabling TLS although it is not really recommended. But disabling TLS broke the automatic sign option and required for legacy users to restart their computers and the application to get it to connect.
With mitmproxy you can enable TLS and Sign in when Zello starts without receiving messages "Can't establish a secure connection" and "can't verify your account reconnecting in XX seconds" and you won't have to restart Zello or your computer after every disconnect. The app will work as before.
I'm using this proxy for the first time so I'm not sure if traffic really is encrypted or not after leaving mitmproxy, but the mitmproxy manual says it can intercept and inject the certificates.
Keep in mind that Zello can decide at any time to cancel the token the legacy app is using for connection and completely disable it. So this is still a temporary fix until we migrate to Zello bridge as another user suggested.
Fireman-Sam
It solves the need for restarting Zello. This was bothering me the most since I needed it to be running unattended and not check every day if it's still working or not.
uni396xt
uni396xt
so the PC app function is ending right... and with zello bridge we could keep it working? What if I run 5-7 instances of zello on 1 pc? would the bridge allow this?
Fireman-Sam
You can define multiple links in Zello Bridge. But you need to enter your network name (not free) or your developer token (free) which expires every 30 days. Maybe some brave person will create a script to generate a new token and write it to ZelloBridge.json every 30 days to keep it running... Meanwhile I'm trying to extend the use of legacy app with mitmproxy as long as possible. Maybe I will have time to try zellostream.py... If everything else fails, we will use Zello Bridge with Work account.
medic7594
Chelmsford, MA
I can assure you Zello is going to have a solution for the Friends & Family network. I have channels on both systems and have been trying different things with them. They are aware there are many people who stream and would like to continue streaming.
They told me this past Friday they plan is to migrate to Zello Bridge and are currently working on a solution for the tokens.
mike619
I have the free zello app on my PC and I went into options and connection and I unchecked the box ''enable TLS'' and it now works like it should.
Fireman-Sam
This is true, but when it eventually disconnects (for instance when you internet goes out and comes back or your router renews your public IP), it won't be able to reconnect. You will get a message loop "can't verify your account reconnecting in XX seconds" until you restart the app. Disabling "enable TLS" somehow breaks reconnects. This is not acceptable for unattended operation, but at least we have good news from @medic7594 (y)
You can test if your app is able to reconnect by signing out manually and try to sign in again without restarting the app.
medic7594
Chelmsford, MA
Are they getting rid of their free two way radio app?
They told me use of the Legacy app is ending on August 12, 2025 for Zello Friends & Family and Zello Work. The replacement is Zello Bridge for both. However there were some issues with security tokens for the Friends & Family network which they are working on.
The Zello app for mobile devices will remain.
RadioChief55
If you are an emergency service, your department can get a free work account. I just got my FD a free Zello work account. You will need to email Zello from your department email give them the required information and a picture of your department ID. Once you get approved, you can set up 16 different feeds. It is a real PIA to set up, but their tech support is great. I had 2 ZOOM meetings with a tech and she was great. She remoted into my PC and set up all the code and then logged into another PC and added 2 more channels on that one. After that, I knew how to do it myself and added 2 more channels on a third PC. To add members you will need to add every member yourself, you can't just send a text or have them scan a QR code anymore.
Hare's the link.
medic7594
Chelmsford, MA
Hare's the link.
I have done the same for my area. Zello support is amazing!!!
We are cross-linking numerous agencies and building an amazing system.
