Hi, this is more of a general question than specific to the Kenwood radios, but I'm trying to figure out the programming options for getting the best possible range from the TK-3402s. The easy options I believe are High power and Wide band (and use the whip antenna). The less obvious is whether to use QT/DQT and what squelch level. I believe that you would not use QT/DQT at least on Rx (no harm on Tx?) and then set squelch as low as possible. Any other settings to be concerned about? What have other's used that gives a good trade-off between range and least annoyance of false receives?
Thanks,
Nick.
Thanks,
Nick.
