GREAT !!! tCutting the end off was all that was needed.
THANKS AGAIN !!!!!!!!!!!!!
As @mmckenna said, It does go straight into the passenger compartment. I used the same pass-through and had trouble getting the wires routed through. I finally found success using a wire hanger and angling it down and slightly to the passenger side. If I ever get a free moment, I'm going to do a write up too.MMckenna, that nipple you cut to get wires into passenger compartment, when you cut it does that opening go right in or do you need to cut something else on the inside of car?
A bore cam (used with rifles) on a coat hanger would have been a great idea for me too, but I ended up taking down one side and the rear of my headliner, which first had the pre-requisite of taking off C pillar trim, which had it's pre-requisite effects of other trim removal.
To an earlier inquiry the NMO mount I used was a Laird NMO LL195 part number NMOHPCNUHFM518. Definitely I felt my hole saw traveled a smidge out of round and made the hole bigger than theoretically intended by the NMO design. I wonder if one of the actual NMO hole saw drills would have performed better than the Bosch drill I used. Quite possible. If I get motivated, I will pull that Laird assembly out and go with a Breedlove mount which seems the size of hockey puck almost, and ain't gonna come out easily at all.
Thank you, Sir !!!!!As @mmckenna said, It does go straight into the passenger compartment. I used the same pass-through and had trouble getting the wires routed through. I finally found success using a wire hanger and angling it down and slightly to the passenger side. If I ever get a free moment, I'm going to do a write up too.
the new NMO roof triband Larsen antenna I replaced the 2/70sh Larsen with is significantly more flexible, a tad shorter, and makes much less noise when it catches and flicks under my garage door every day.
Which Larsen did you go with?
I'd like to know, too.
I was placing a Tessco order and noticed that Larsen has a couple of new tri-band designs based off their latest model. Two of them had a higher flexibility whip. I ordered one of each to give them a try. Unfortunately won't be shipped until May, if our purchasing department doesn't totally $#^#it up.
Here is my pic, and it is darker than the shiny whip of the 2.70sh. This new triband doesn't impress me as perfectly matte black color... seems somewhere in between almost. Honestly I have to take another look at it and see if I can say what color it is.
note: the 2/70sh is the one towards the front of the vehicle and is not on the NMO mount, but just standing there for comparison.
Do you have any issues with water infiltration on that fuse holder, or does it have a water-resistant cover?
