“a lipo safe box inside an ammo can” I’ve heard that LI-ion cells can come in differing chemistry makeups. And so far the only ones I’ve heard of that have caught fire or exploded were the ones the early experimenters were using on the RC circuit (model radio control airplanes, etc,). The cell phone and radio batteries we discuss here only seem to swell. Can someone expound on my observations? Do we really need a metal ammo can to protect against fire and/or explosion for an SDS100 battery? Why , when we don’t place our smart phones inside that ammo case each night when we charge them. There’s got to be a difference in the chemistry or how a better quality battery is builtUpdate: i've cycled the "good" battery a few more times, then charged it fully then discharged it to 3.85V for each cell. I let it sit for almost 2 months in a lipo safe box inside an ammo can and just took it out. there is no swelling and the cells measured 3.811 and 3.808 vdc. if they only made all batteries like this.I'll sleep better now leaving this in the scanner on the desk, or when it comes time to trading it for an SDS200. FWIW, the date code on this battery is 2018. I've seen 2018, 2020 and 2021 batteries swell so there's still no way to identify a culprit battery. With my luck this will swell overnight and break the radio. fingers are crossed that it doesn't!
It doesn't seem to be temperature related or age related or during charging or if just being left in a drawer in different state of charge. It seems to be a quality issues with the cells, too cheap and low quality. I had one cell of the three swell and cut that out, they are all in parallell, and the two remaining cells have been working fine without swelling.In any event, what is the temperature at which these SDS batteries start to swell?
I had already received the replacement large battery. My thin battery swelled at room temperature while sitting on a desk on its original thin battery case plastic cover. It was neither charging nor had recently been charged. Mine was one of the first. Uniden Corporate requested that I ship it to them for inspection. In return, I received a second large battery plus charger.It doesn't seem to be temperature related or age related or during charging or if just being left in a drawer in different state of charge. It seems to be a quality issues with the cells, too cheap and low quality. I had one cell of the three swell and cut that out, they are all in parallell, and the two remaining cells have been working fine without swelling.
This is similar to what I experienced. I took the battery out of a unit that sits on external power 24/7 and set it on the desk. After a couple of weeks it started to swell. It was charged when I took it from the scanner, and was not being charged when it expanded. Very scary.I had already received the replacement large battery. My thin battery swelled at room temperature while sitting on a desk on its original thin battery case plastic cover. It was neither charging nor had recently been charged. Mine was one of the first. Uniden Corporate requested that I ship it to them for inspection. In return, I received a second large battery plus charger.
You did well.I had already received the replacement large battery. My thin battery swelled at room temperature while sitting on a desk on its original thin battery case plastic cover. It was neither charging nor had recently been charged. Mine was one of the first. Uniden Corporate requested that I ship it to them for inspection. In return, I received a second large battery plus charger.
That's true for most R/C models. I have both cars, motorcycle, helicopter and airplanes and they all draw a lot more current than a scanner and their Li-Po battery cells get hot after every use. The SDS100 doesn't draw enough current to heat up the battery. I had my SDS100 battery always fully charged to be ready to take the scanner with me so it never charged for an enough time to heat up but still swelled.If it’s hot or not let it return to the ambient temp before attempting to charge. I’m just taking a shot in the dark here, remembering the recharge process from my son’s RC vehicles he raced.
I would have preferred Impress style.Uniden should have went with a battery similar to the Icom R30. Zero issues!!!!
