I updated my firmware with the latest last weekend, and it still cuts out briefly.
Also don't like the fact that I can't treat the scanner as a cellphone, in terms of charging it and keeping it plugged in. This is my first scanner, and I want it to be portable, I can't justify buying a mobile scanner for my car, I want it in my house, or out on a walk. Hence the portable handheld. Problem is that the stupid charging circuit is not built to charge and keep the power on. Not to mention the re$arded "Charge?" prompt that pops up that asked you to charge the batteries. I don't intend to run it on non-rechargeables, so I don't want to see that stupid prompt, and it also stops reception until the prompt is answered, so I'm double fahKKed.
What I do with my 396 is use a separate smart charger and use two sets of rechargeable batteries. /this way I always have a backup set ready to go. The smart chargers are a lot friendlier to the cells than charging in the radio.
I thought I would start a thread with user tips and tricks on these new scanners since they have now been out for awhile.
WARNING: Some of these cause the scanner to lock up, just remove a battery and reinstall it and turn it back on. Make sure your scanner is backed up before you do any of this.
Press and hold 2, 0 and on--Birdie Search 5K steps
Press and hold 3, 0 and on--Key Touch Test/Headphone
Press and hold 1, 0, Yes and on CAUTION THIS IS ALL MEMORY CLEAR
Press and hold 9, Chan and on--Clock Test
Press and hold 4, Chan, and on--Tone Out Stand By Tone out 1 163.400 CH:1 NFM A:300Hz B:3000 Hz
Press and hold 3, Chan and on--Boots up no LCD screen
Press and hold 2, Chan and on--LCD Contrast ADJ test
Press and hold 1, Chan and on Checker Board screen Press a key and switch to key touch/headphone
Press and hold 1, Dept and on--USB Serial Test
Press and hold 3, Dept and on --LCD Contrast Adjust Test
Press and hold 1, Syst and on--Close Call Test
Press and hold 2, Sys and on--USB Serial Test
Press and hold 3, Syst and on--Checker Board LCD
Press and hold 4, Syst and on--Search Test 5K steps hit syst or dept to change step sizes
Press and hold 6, syst and on--TOne Out Standby
Press and hold 7, Syst and on--Trunking Test 1 Moto, 2 EDACS Wide, 3 EDACS Narrow, 4 LTR
1 Motorola--Displays 851.0125 CTRL press DEPT changes to VOICE SYS changes back to CTRL Avoid changes to LSD Press Menu to go back to Trunking Test Menu
2. EDACS Wide Displays 851.0125 CT, Dept changes to VC, System changes back to CT
3. EDCAS Narrow, displays 894.0125 same changes as above
4. LTR displays 851.0125------
Press and hold 8, Syst and on NWR-SAME TEST 162.400 Press Dept to change to WX Alert Test---Turn off and turn on holding on and it boots up to Monitor Weather-Turn dial to change stations
Press 0 and Syst and on--Load Test Data
Press and hold 3, 9 and on Scan Rate Test
Press and hold 5, 9 and on Software Version Test
I held down 7 Syst and on and the trunking came up is there way to change the Freq?
To make a Debug log file:
1) Power up while holding AVOID.(adds Set Debug Log Mode to settings)
2) MENU --> SETTINGS --> Set Debug Log Mode --> SD Card File
3) Monitor for a bit (a minute or two is plenty).
4) MENU --> SETTINGS --> Set Debug Log Mode --> Off
5) File is in the debug directory on the SD card.
