8/8/19 - EZ Scan Update
Wackyracer
Uninstalled and reinstalled but no luck on both computers am able to update uniden have any more guess thanks for the reply. Wayne
Try turning off your antivirus and any VPN if you run one.
AC9BX
Lockport, IL
I'm thinking VPN or proxy .... 'reset by peer errors' are often due to a DNS outage or error, the specific DNS server you're trying to go through has a problem, or there's a firewall or Intrusion Prevention System blocking the request.
wmac75
Upstate SC
Thanks for the help finely got it to work had to hook up old router new one would not let it update Wayne
Fab57
Metz (France)
Good afternoon,
I also have an issue with the search page, the SKIP touch doesn’t work (configured as skip or lockout) and the TRX says: No lockouts in the SEARCH MENU but there are.
I use the last version of EZscan. This problem never happened before!
The only solution is to delete/clear all lockouts through the software. It’s fine for a couple days but then...
73 from France.
Fabien
Fab57
Metz (France)
In the new Search tab there seems to be a bug in the "'add lockout"' part.
When i tried to enter some local paging frequencies, for example 169.650; it only shows 169.00000
Tried several other freq's and all have same issue; just the mHz part before the "."' no KHz
Also tried a ","' and "':"' as separator but no luck so far.
In the same section the "'Clear selected"' button doesnt always work for the first 5 frequencies...
Hope this can be fixed?
I have the same issue on my side. First time I face a such bug with EZSCAN. It was fine before.
I hope a new release soon.
73
Fabien
