996XT install coming.....
hill2jb
Virginia Beach, VA
Decided, after much debate, to remove my 2 DIN head unit, install a better, but cheaper 1 DIN head unit, and use the other space to install my (hopefully coming soon) BCD996XT. Read a ton online, asked a few questions on here, and decided that this was the best route, with the cleanest install that I could hope for. It will also keep my equipment out of sight (mostly), and out of the wifey's seat. I will try to post pics of the entire install, if I get time. I will most likely post a pic of the finished product, and give a report on whether it went how I expected or not.
N5TWB
Sand Springs OK
I'll be looking forward to your further posts and just thought I'd send some encouragement to you on your plan. I have the same type of install in my Nissan XTerra and have loved it since 2008. I had Best Buy handle the install since that was where I bought the 1 DIN AM/FM/CD to replace the factory unit. Also, I had no tools or skills for accessing the dash area.
hill2jb
Virginia Beach, VA
So I started today :). Ripped out the factory stereo, which was in fact a nicer one than the one I just finished putting in.
My goal is this: clean install, no wires showing, with a rigrunner providing the power, connected straight to the battery, with room to grow.
First step: remove old head unit, put new one in. My scanner is backordered, so I popped the 1 DIN head unit in with the spacer, which will be swapped out when the scanner arrives. I'm going to try to include some pics in this post.
Below is basically a view of how much garbage was behind the kit that was already in there. I was able to clear a ton of it out, save the GPS cable and puck that were already on my dash (perhaps for future use with the new scanner), and install a cheap head unit.
cg
Connecticut
If you know someone in the area with a 996, you might be able to get their DIN sleeve and preinstall it. Very few people use them.
chris
hill2jb
Virginia Beach, VA
Antenna shipped yesterday. I will try to show some install pics when I get around to installing it next week. I plan on drilling the roof like I did for my 2m, and using an NMO mount.
WatnNY
Knoxville, TN
Looks like you know what you're doing! And YES to drilling! Good man!
Mike
hill2jb
Virginia Beach, VA
Thank you. This is going to be a slow process. Scanner is backordered, with a ship date of later this month. My powerpoles, rig runner, and antenna should all get here this week. I'll try to install it ASAP, and make sure the antenna receives well, using my pro-106, and that the rig runner works and can power my 2m radio.
hill2jb
Virginia Beach, VA
Alright, so I got part of the install done today. Rewired my power, drilled the antenna and routed the coax. All in all, it went about how I expected it. The antenna install went off without a hitch, since I pretty much knew what I was doing there. Decided to drill 18 inches in front of my 2m antenna, instead of offsetting it towards the back. It was easier this way, and it kept the longer antenna towards the back, so there is less of a chance of it coming in contact with the scanner antenna while transmitting.
The thing that took forever was putting the Anderson powerpoles together. Little tip: when they suggest you get the proprietary crimper tool... DO IT. These things were a b**** to crimp with a terminal crimper and another crimper tool. They have to be perfectly bent inwards to fit into the terminal housing. I messed up about 4 pairs of them before I got the hang of it without the tool. Not my best work at all, but they don't slide out of the crimp and they fit in the housing. I'll be ordering the tool soon.
First thing was to splice a 50 amp fuse inline with the 10 gauge wire I was running. I only did the positive side, mainly because the rig runner has a 40 amp fuse on the input, and a fuse for each output. I'm not really worried about the ground wire shorting out and blowing my equipment up. Maybe that's foolish, I don't know. If you think so, please tell me! Any constructive criticism is welcome.
Next thing was to get the wire through my firewall. The spot I had run the old wires was way too small, so I cut the inside of the seal and made a path. When I get everything set up how I want it, I will put some silicone sealant on the cut to keep noise and moisture out.
I decided to put the rig runner out in the open, so if I ever want to take anything out, change fuse arrangements, install more radios, I'll have easy access to it.
I tested the voltage each time I hooked up a new run of wire, at the connections on each power pole. I am getting about 12.49 volts at the radio.
I tested the ground, coax to tip, and tip to antenna terminal connection on the antenna, and they are all good.
The antenna is a Larsen UHF/VHF/800mhz.
Here are the pics.
First one is of the old wiring.
Second one is the old wiring going through the firewall grommet.
Third and fourth is the new zip cord coming through.
Fifth is the new stuff at the battery terminals.
hill2jb
Virginia Beach, VA
More pictures:
hill2jb
Virginia Beach, VA
RIght now, I'm just using my pro-160 to gauge the antenna's reception. So far, it is AMAZING! I'm hearing stuff that normally is broken but readable, and is now perfectly clear. I hear Lynchburg PD from my house, just as well as I head them in the city which is about 20 miles away. I'm impressed.
cg
Connecticut
I solder all the PowerPoles I use. It makes it much easier to deal with them.
chris
cg
Connecticut
Yes. I put a bit of flux on the wire, put the connector on it, and flow the solder into the connector. The only thing would to be sure the curve on the connector tab is facing the correct way first. If you are using 2 conductor wire you may not have room to twist it around.
so no crimping, just put it in the metal piece, solder it, and stick it in the plastic housing?
chris
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
Isn't it just amazing how well an antenna system works when you install an NMO mount on a vehicle? I still can't believe all those hobbyists who insist on using magnetic antenna mounts because of some vanity issue? I've own 20 cars and trucks over 40+ years, and even those I leased NEVER had an issue with permanent antenna mounts. I've sold three of my vehicles to ham radio operators and communications enthusiasts because my cars have been "pre-wired" with antennas, power, and auxiliary systems.
Score ONE for Hill2JB for a great installation! Good job; keep those photos 'a-coming!
K4RBT
996XT install
Liked the way you are doing your install. I have a 2011 Suzuki Grand Vitara that I have been going over to see how to install a dual band ham radio and some kind of scanner.
Installing the ham radio on the side of the console, for me, is not a good idea as the main computer that does everything is located there. I am having enough problems, which the dealer cannot fix, with the environmental controls, plus it controls the air bags, which this vehicle has all over the place. I am going to make up my own antenna cable/mounts. I will use the Larsen NMOHF mount which does not have any exposed center conductor and a Rg-58 that has two shields, insulated from each other. I will ground only one end of the outer shield making a Faraday shield to keep any loose rf at bay. Wiring for the air bags is everywhere.
I am thinking about using a radio I can remove the head and mount it in front of the overhead console. The scanner might do the same as the 996T I bought used came with the head kit.
I worked in public safety communications maintenance for a number of years. the vehicles are becoming more and more installation unfriendly. I think my next vehicle will be a police/fire fleet vehicle as they do not put a worthless plastic console in them. I cannot remove the one in the Vitara as it has the shifter and brake handle incorporated in it. As Dr.Sheldon Cooprer says, " I would if I could, but can't so I shan't."
Once spring gets here, I will start and take photos.
hill2jb
Virginia Beach, VA
What did you use to make the holes for the antennas?
3/4" Ice Hardened
One of these but with a regular looking drill bit in the middle. The bit basically helps guide the hold saw into the metal. Without it, you would pull the trigger on your drill, and it would slide across the roof of your car lol.
There are specialty tools for drilling NMO mounts, but I find this just as effective. I just sand the edges a bit once I make the hole, and make sure the mount is on there tight.
hill2jb
Virginia Beach, VA
Thank you! Hopefully my scanner comes in tomorrow, and I can start programming it.
hill2jb
Virginia Beach, VA
Scanner came, ran into issues
So I got the scanner in the mail, and after a small learning curve, was able to program it with all my local stuff. The radio works well, scans decently fast, and looks sexy.
I ran into an issue when trying to mount it in the truck. Apparently, though my installation kit says it will support two single DIN radios stacked, I can't figure out for the life of me how to get them both in there. I feel like I may be missing a piece.
I'm going to try a different kit. The original was a Mesa or something, and the new one will be a Scosche TA2053B
