996XT Rec Out
SteveEJ
Some where out there..
Hello,
I just received my 996XT and am trying to record. I plugged into the 'REC OUT' on the rear of the radio and input that into the 'Line in' on my desktop. I cannot get anything to play or record. Using the 'Ext Speaker' works but not the 'Rec Out'. Am I missing a setting here or something?
TIA,
Steve
iMONITOR
Silent Key
S.E. Michigan
There is a program setting for each frequency/talk-group that you need to set when you want the audio output to go to the Record Out jack. This allows you to pick and choose what gets recorded. I've never done it from the front panel of the radio itself, I've always uses software like ARC-XT, or ProScan.
SteveEJ
Thanks,
I am looking at ProScan now and tring to decide if I want it or not. How is the REC OUT set in ProScan?
I am tired and a bit stumped..
Thanks!
For Conventional & Trunked Systems
Menu > Select System > Edit Sys Option > Set Record > All Channel
Otherwise you have to set Record to Marked Channel & you have to select which conventional frequencies and trunked radio talk group ID's you want to record.
This is the menu in the Radio, not proscan
