Adapter Recommendations
Salvatorejrc
I interchange antennas frequently on my sds100, and I was wondering if there are any adapters that I could put on that will take the damage and wear over time, rather than the scanner itself.
iMONITOR
Silent Key
S.E. Michigan
The SDS100 comes with a SMA/BNC adapter. You can also buy coax jumpers with BNC & SMA connectors.
vagrant
ker-muhj-uhn
California
I use SMA to BNC adapters on my transceivers, receivers and scanners that often see the antenna or coax disconnected.
Salvatorejrc
I mean like an SMA male to SMA female adapter that goes on the unit as a fail safe for abuse when changing antennas. Not an SMA/BNC adapter
CT
Have you tried searching the Internet? The answer is inevitably found there.
Salvatorejrc
Yeah well I am asking the forum because some products are made, and designed better than others. Rather get a recommendation on here before buying
jonwienke
More Info Coming Soon!
VA
I make a BNC adapter specifically for the SDS100. If you do a search on my username, there are numerous customer posts about it.
