ADCR25 P25 / DMR Receiver
RayAir
Harris OpenSky
Any chance Harris OpenSky decoding could be developed.
It uses the AMBE+2 vocoder, 4 slot TDMA.
systron
any chance for dPMR and TETRA ?
nice feature, to work as a "usb-dongle" for digital voice !
Boatanchor
How do you take this little gadget on the go with you in your vehicle if you need a computer to run the software? Or am I missing something?
Mike
Once you setup the conventional or trunking channels in a scan group using the computer, you unplug the USB lead and plug the ADCR25 into a USB cig lighter power adapter or other USB port in your car.
As soon as the ADCR25 receives power it will start scanning/trunking.
You still need to feed the ADCR25 audio output into an 'AUX' port on your stereo, use a bluetooth audio adapter or some other amplified speaker if you don't want to listen on earbuds.
I'm not convinced of the merit of this device in a mobile environment though. It is probably OK if you just want to monitor a few conventional freqs or one trunking system, but for anything more you just don't have enough (any) control over what is going on.
As a PC connected unit it does work quite well.
Don't forget, this is only the first version :)
RU3ANQ
Moscow, Russia
With the current firmware ADCR25_PRO2 board receives conventional direct DMR channels and it decodes repeater channels as well. It doesn't decodes Motorola CON+ and CAP+ systems due to its proprietary closed technology. In my future plans is to add Motorola RAS channel receiving capability (not decoding RAS but the ability to receive voice in RAS channels).
RU3ANQ
Moscow, Russia
New FW5.5 released:
1. P25 trunk tracking improved algo.
2. NXDN voice decoding greatly improved.
3. Search engine made more reliable.
4. Memory scan algo modified to more reliable.
5. Some minor bugs fixed.
Boatanchor
Wow!!!
I wish Unden would come out with firmware updates as frequent as this guy :)
Why is it that a RU3ANQ can produce a good little product like this, with firmware updates almost every week addressing bugs that users report, yet a huge corporation like Uniden struggles to produce 2 firmware updates in 18 months for it's 'flagship' products?
They really are becoming a (sad) joke.
Loving your work Andrey..
I look forward to a multi-band version too.
RU3ANQ
Moscow, Russia
Also fixed a bug (was in case of TSBK only trunks) with CHANNELS history - all hits was placed to the 851Mhz frequecny. Now hits placed to the right voice frequencies.
RayAir
Wow!!!
There is absolutely no reason why Uniden or "Whistler" haven't been able to put out a DMR capable scanner by now. Well, maybe there are two reasons:
1- They just don't care that much about their scanner product line and don't care to invest in it.
2- They "may" have received money from Mother M not to make a DMR scanner so Mother M can continue to market MotoTRBO as "unscannable" and "private"?
Scanner manufacturers are so behind that I think theyll become more and more useless as more people go the software, SDR and/ or commercial radio route for monitoring the many digital modes you can't hear on a scanner.
I know I have no use for a scanner today, except to use it for discriminator tap audio.
I'd rather give my money to this Russian engineer and the developers of DSD. They are the future of scanning. I am thankful for people like them!
Thank you so much.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Let's keep this thread focused on the ADCR25 and not Uniden. No more Uniden posts, please.
Boatanchor
Other's, take note..
From V4.0 to V5.5+ and several new digital voice modes supported in the last few months alone.
This is what you call product support & devlopment. This is exactly what is required if a receiver is going to be expected to monitor more than one DV mode..
What’s new in firmware and control software 4.0
1. Software and firmware stability improved.
2. More functional and reliable search engine (Noise Floor parameter added to RF SET).
3. Separate DMR Timeslot 1 and Timeslot 2 reception added (DMR TS1 and DMR TS2
modes) along with both TS1 and TS2 reception in DMR mode.
4. Number of memories increased from 50 to 150.
5. NAC (CC in DMR) filter per memory channel added.
6. Group filter improved: EXLUDE option added, banks added.
What’s new in firmware and control software 4.1
1. Search engine improved.
2. DMR data traffic search added.
3. Overall stability improved.
What’s new in firmware 4.3 and control software 4.3
1. P25 CC scan feature added
2. Logging added.
3. Dedicated group filter for trunk tracker added.
What’s new in firmware 5.0 and control software 5.0
1. NXDN4800 (IDAS/NEXEDGE) decoding added.
2. Yaesu C4FM System Fusion decoding added (V/D 1,2 mode and Voice FR mode)
3. Search improved.
What’s new in firmware 5.3 and control software 5.3
1. NXDN9600 decoding added.
What’s new in firmware 5.5
1. P25 Trunk Tracking improved.
2. NXDN9600 (Kenwood NEXEDGE 9600) voice channels audio quality improved.
3. Search engine for NXDN and DMR improved.
4. Overall performance made more stable.
5. Started work on NXDN (IDAS and NEXEDGE) trunk tracking.
RU3ANQ
Moscow, Russia
SW 5.6 and FW 5.6 released.
New to FW 5.6:
1. P25 Trunk Tracker: Moto "supergroup" tracking added.
2. CHANNELS window bug fixed (was on TSBK only trunks)
3. AUTO SCAN and MEM. SCAN improved. Red blinking added.
4. Frequency changing bug (when frequency difference 30Mhz and more) fixed.
download:
http://hrw.3dn.ru/load/0-0-0-22-20
