AFRRCS - Alberta First Responders' Radio Communication System - INFO HERE
Chris21773
Edmonton Alberta
Pleasure to be apart of this discussion. You will be able to tell pretty quick that I am new to this hobby and my question for all you well knowledgeable individuals is will a Uniden SDS100 be an effective scanner for this new radio system? Also when you say encrypted what exactly does that mean when it comes to scanning.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
The SDS100 will receive this system quite nicely.
"Encryption" is the practice of using secret codes to make a radio transmission unreadable except by those who know the code. This secret code is loaded into the radios that the agency uses and not provided to any other party. Scanners are unable to follow an encrypted conversation and there will never be a scanner or other radio receiver that will defeat encryption as it is against the law to do so.
VE6BRW
Grande Prairie, Alta
New id's showing in Grande Prairie
Jan 3,2019 @ 22:30
3505
4100158
4100161
4100163
4100165
Jan 9,2019 @ 20:30
356
4010308
4010310
4010314
357
4010316
4010317
4010327
also still hearing AHS Security at QEII hospital on
460.3850 Mototrbo tier 1&2
Nothing in the 410mhz area though
VE6RSU2
Calgary, Alberta
Radio ID update from here in Calgary. Monitored on site 098 (Bankers Hall)
- most TGs are being rebroadcast on the surrounding sites.
428
4017111
4017227
4017233
3495
4100447
4100556
3498
4100529
4100532
3499
4100542
4100531
4100533
4100540
4100538
3511
4100508
4100502
3510 (from site 101 Forest Lawn only - not broadcasting on any other tower that I can pick up)
4100115
4100117
Also getting RCMP on 2964 with Ids like: 4449447 & 4449660. PACS still seems to be going strong here however - wondering if the during the switch over (this year?) we will get some simulcasting on PACS/AFRRCS? If so we might be able to nail down a few more talk groups.
kayn1n32008
ØÆSØ
Sector 001
Transition to AFRRCS is well under way. I would expect most detachments to be on AFRRCS this year.
At least one person I know that monitors AFRRCS and PACS saw zero patching when switching from PACS to AFRRCS.
lzrman
Grande Prairie
Saw TGID 1151 w/ Encryption in Grande Prairie today.
Also saw radio
i4020011 testing on TGID 702 CoGP-CET and i340215 on same channel
lzrman
Grande Prairie
Jan 3,2019 @ 22:30
3505
4100158
4100161
4100163
4100165
Jan 9,2019 @ 20:30
356
4010308
4010310
4010314
357
4010316
4010317
4010327
Who is 356/357?
and how do i listen to 460.3850? i plugged that in as a normal frequency and it sounds horrible lol
Jay911
I think 1151 is in the range of groups we've seen AHS protective services (412xxxx) on before.
356 and 357 with those IDs are in the range that Sheriffs use. There's some discussion that 356, 357, and a few others in the 35x-36x range are the Sheriffs part of ALERT, and 410xxxx radios (and the 35xx talkgroups) are another part of ALERT.
402xxxx I think we've said was Agriculture & Forestry. 34xxxx is Grande Prairie County (not sure if just FD or FD + other users).
As for 460.385, this is off topic for this thread but that's a MotoTRBO/DMR frequency. You would need a radio capable of receiving DMR to listen to it. (Didn't you get an SDS100?)
lzrman
Grande Prairie
SDS100 Yup, I'll just program it in, tried to on the 396 but no go for 460.385.
34 is Strictly County Fire and County CPO
VE6RSU2
Calgary, Alberta
1002 active today (non-encrypted) on site 098.
Had a 501 agency dispatcher working AHS on "Mutual Aid 12" - I think I heard Red Deer named. The dispatchers set up the channel and that was the last I heard of them "I will set up the conference". I was looking at the published list and I don't see a listing for 1002.
Finally bagged Alberta Environment on 4046.
