Air Ornge frequencies
ve3vav
Shelburne On
I am looking for the frequencies for Air Ornge ambulance. The frequencies listed which there are only two seem to have no action I am sure there is more frequencies I just can’t seem to find them anywhere
ATCTech
Also, take note of the following regarding their 400 MHz UHF frequencies. What I posted last September is still the same today, it's not operating around the GTHA as a true "repeater" but as 2 cross-linked simplex frequencies.
Beyond that, 150.100 for talk with ground units when arriving on scene or to a local CACC and that's about all you can expect to hear around these parts. And of course 150.100 is also simplex so don't expect too much range hearing the CACC transmissions.
129,275 (AM of course) is active from time to time with fixed-wing traffic talking to MEDCOM ("Pulse" callsign flights on the ATC side), the Pilatus PC-12s mostly, and they only do transfers to and from Toronto area locations. None of the PC-12s are based in the GTHA.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Not sure what that is?
Referring to the FleetNet replacement trunked system. Part of their digital repeater network.
That would be this one:
Tx 773.0688 AIR AMBULANCE (VARIOUS AIRCRAFT)His Majesty The King in Right of The Province of Ontario (GMCB)
Rx 773.0688 AIR AMBULANCE (VARIOUS AIRCRAFT)His Majesty The King in Right of The Province of Ontario (GMCB)0001872275
ve3vav
Shelburne On
Would it be like DMR or something with it’s own talkgroup?
FleetNet replacement? I'm not aware of a replacement yet? I must be behind the times.
ve3vav
Shelburne On
So the new Motorola system will all be encrypted I know the OPP will be, but ambulance? I thought the OPP were moving to the new system but was unaware of the others
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I will certainly be adding these. Honestly you never know what will show up on a frequency at any time. Always nice to see some new ones of these popping up. Nice find btw.
I see the bulk of them were licensed as of April 1, 2022. I have also put those in my scanners.
So far, only have heard 149.335 MHz in analog. Mentioned 3239 which could be a land ambulance in Peel or York Regions. Sounds scratchy at times, like a portable.
Forts
Mentor
Ontario, Canada
Yes, EMS is encrypted on the new system as well.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
150.83 also came over with a flashing 173.8 PL. When I looked that up, it came back as Kawartha Lakes Fire South (Pontypool) Still only seeing activity on 149.335. I imagine it's units using portables up at Etobicoke General while off load delayed.
