Airspy Spyserver and DSD+
vince48
Central Valley, CA.
Greetings,
I have my Airspy R2on my Pi4 and using Spyserver to connect to it via my LAN, I want to use DSD+ to decode DMR on the 70 cm ham band. If I use the DSDPlus Ui plugin, it says the airspy is in use and does not connect to it.
Is there another way to use DSD+ while using the Spyserver?
vincent
vince48
Central Valley, CA.
No, not yet. that's my next task after I finish up a few outside chores. thanks for the reply
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Greetings,
vincent
You've got another issue. It's the issue with software/drivers/configuration on the actual RPI, with either/both the spyserver.config configuration or the installation of the udev rules (which are part of airspy-host tools.
Mike
vince48
Central Valley, CA.
Mike
Hi mike,
can you kindly explain? Not sure I follow your reply. TIA
vince48
Central Valley, CA.
Hi Scott,
my airspy and airspy server is installed on my pi4, but i connect to it by my LAN using my windows 11 machine where DSD+ is installed
