A few points:
Enjoy the build out of your county's new system, but don't get too hung up on all the minutia. Realize that often there is some method to the madness, even if you might not fully understand it or have a high level grasp of the nitty gritty of these complex systems.
- Yes, a constant carrier that resembles a control channel is a test pattern. Perfectly normal during the early buildout
- It's entirely possible that not all subsites are on the air yet, accounting for "poor audio". Or they're purposely testing coverage by compromising the signal to get a "worst case" scenario. From personal experience: years ago when our ASTRO 25 system was being built out and only 2 (out of 12) subsites were on the air, we would drive around with APX portables with stubby antennas on low power inside the vehicle with the windows rolled up just to see if we had any coverage with the system so compromised. Anyone listening without knowledge of the situation would've likely formed a negative judgment of the system, which frankly is why the county personnel and MSI ST's should really do this testing on encrypted talkgroups to avoid uneducated assumptions by listeners.
- Get used to seeing those registration rejections, because they're actually much more common than you might imagine. It's only recently that Rick has Unitrunker 2.1 versions actually displaying them (at my request), prior to that they went ignored. What is technically happening is that a foreign subscriber is requesting a Working User ID (WUID) on the system, and is getting denied. A look at the raw control channel log would reveal all of that info. How they are happening is largely irrelevant...could be a radio passing through, could be ducting from a control station, etc. Much ado about nothing, I literally see dozens of these rejections each day on a number of local systems.
Best explanation ever! But no one will read this and the shenanigans and non scientific wild ass guesses will continue!
Quite a bit of bad decoding there. Motorola ASTRO 25 systems can only have up to four channels flagged as control capable, not to mention that 867 and 871 are not valid channels in the USA for a PLMR system.Current Site
SYSTEM:A7E[2686] NAC:A71[2673] RFSS:01[1] SITE:01[1] LRA:00[0] STATUS:ACTIVE RFSS NETWORK CONNECTION
PRI CONTROL CHANNEL:0-21 DOWNLINK:851137500 UPLINK:806137500
SEC CONTROL CHANNEL:0-2608 DOWNLINK:867306250 UPLINK:822306250
SEC CONTROL CHANNEL:0-269 DOWNLINK:852687500 UPLINK:807687500
SEC CONTROL CHANNEL:0-3328 DOWNLINK:871806250 UPLINK:826806250
SEC CONTROL CHANNEL:0-371 DOWNLINK:853325000 UPLINK:808325000
SEC CONTROL CHANNEL:0-561 DOWNLINK:854512500 UPLINK:809512500
m type P25 800 MHz and it
Are you set for Phase 2 P25?So I must have an error in programming the HP436. I have the CC's and the TG and a wild card programmed but no joy. not hearing a thing.
System type P25 800 MHz and it selected the default trunk tables. What say ye?
P25 Standard is all need for both Phase 1 and Phase 2. (P25 Trunk - System Type in Sentinel).Are you set for Phase 2 P25?
Then I dont know. I have heard then last week on my Unication, but haven't tried recently due to it just being test counts.P25 Standard is all need for both Phase 1 and Phase 2. (P25 Trunk - System Type in Sentinel).
It's all they technically need, but it's likely that he will need to acquire a Unication or SDS series radio - or a SDR / free software solution like SDR Trunk or OP25.P25 Standard is all need for both Phase 1 and Phase 2. (P25 Trunk - System Type in Sentinel).
