ACSO switched to NXDN on 158.850 at the end of last week. Guess NXDN wasn't secure enough for them. They are also 100% Encrypted.
Anyone with inside info on this one?
Allen County SO is buying NXDN gear.... Harlan County's Interop system is supposed to be trunked, the paper I saw points to NXDN as well....
According to the latest rumor Paris/Bourbon County will be going "digital" in October... they carry Kenwood HTs right now, will reportedly be getting new radios doing the digital thing... don't know which flavor.
Hart County is modifying the following licenses for NXDN:
WNMT203 – Hart, County Of (Sheriff, Fiscal Court)
WPNX935 – Hart, County Of (County Jail)
WPOY234 – Hart, County Of (Fire)
WPUD788 – Hart, County Of (Solid Waste)
You guys are not totally SOL. You can monitor NEXEDGE systems, but you'll just have to buy a NEXEDGE capable radio and either have it programmed for receive only, or buy the programming software. Monitoring systems like NEXEDGE, Pro Voice and MotoTRBO can all be done, if it is not encrypted, by just buying the proper radio equipment yourself. I am sure the radios are not cheap, depends how bad you want to listen.
I do know for NXDN there is a basic encryption scheme that comes with all radios. It has to enabled. I am not sure on the amount of codes, but Kenwood lists this built-in security system as "basic" security. I haven't read the document in a while, but I think the number of possible code selections for the basic built-in encryption was less than 30,000. I know, that is still enough to stop most listeners, but whoever programs the radios has to go in and select this option. Most likely, they will just run normal NXDN. Aftermarket encryption boards (DES/AES) can also be installed as an option.
Good luck.
Update: The built-in encryption system on Kenwood NXDN radios, if enabled, has 2^16 possible keys, or 65536 possible keys.
So you can just program a radio to listen to any nexedge system? You sure about that?
What if it's trunked?
