Firmware 1.08 is now available for the AnyTone D578
Yes sir, we did speak on TG 3104. I have installed the radio in the car and so far the only thing I am going to complain about is the audio quality, I have the radio installed in my Jotto Desk center console and its hard to hear. I am actively searching for an external speaker and will have to report on the difference.Good luck with the new 578 ahbood. Will look out for you on DMR to discuss your opinion. Think we spoke on Arizona TG 3104 previously when I first discussed my experience with the 578. I’ll look for you there or on So Cal 31066.
I HAD a 1.06 version (returned for other issues) which would lose DMR audio for a while sometimes after updating the codeplug. Never did figure why.I've had one since early December. I was pretty impressed with it overall, especially the ability to configure the rig to your preferences... very similar to the D878. Unfortunately, however, my D578 was one of only a few that had a problem with the firmware update from 1.03 to 1.05. Somehow during that process, I lost all DMR receive audio. Everything else seems fine... just no RX audio on any digital channel. Anytone reports that they are working on the issue and may have a solution sometime next week. In the meantime, I'm watching the digital contacts quietly pass by on the display.
@gman1971 , You are correct over the past couple of days, when running the frequencies or memories scan with Digi Mon activated,
I also noticed that the radio freezes...
I wasn't sure if it was linked to the USB port always connected to my PC so I disconnected it but no improvement.
These bugs are really annoying and unacceptable.
The more I test it, the less I like it....
I am using Hytera as said before and we shouldn't be comparing "oranges with potatoes".Respectfully, it this some sort of manufacturer shilling?
The issues with SFR hanging up and freezing are still all there with 1.11. After using an XPR5550e for several months I can safely say the 578 adio is slow!!... it chews the first 1/2 second of nearly every transmission... especially when GPS and other features are enabled, etc... Like I said, I ended up replacing it with an XPR5550e.... never looked back.... and speaking of looking.... I don't need a magnifying glass to read the screen anymore either!!
Good times.
G.
G. Are you programming your XPR5550e yourself? Looking to get one, but I'm finding programming software and cables expensive. Your thoughts are appreciated. JimRespectfully, it this some sort of manufacturer shilling?
Good times.
G.
Anytone 578 is definitely a far cry from the big professional DMR radio manufacturers and clearly less expensive.
I am not using GPS or APRS and before the firmware update the radio was frozen after a few hours of DMR scan.
I agree, after many hours the radio is getting slower (less responsive to the button) but no sound problem on my end.
I made the customization of the display which has better readability.
Once again I got answer from Anytone support team which I never ever get from Hytera after 5 years....
Cheers
The cable is free. Every XPR mobile radio comes with an ACC plug with pins. Find a free printer cable anywhere, & cut it by the plug at the printer end. I’ve spent the five minutes a few times making the cable. This way, the mike doesn’t need to be unplugged whenever programming is needed, & it’s free.G. Are you programming your XPR5550e yourself? Looking to get one, but I'm finding programming software and cables expensive. Your thoughts are appreciated. Jim
The 878 has a chnnnel option option called Slot Suit that allows the radio to TX on whatever slot it hears traffic. Used with a 578 in SFR mode, you could use the same channel programming for simplex or repeater use, but the radio would be switching slots constantly if there was a 3-way conversation, or it started intermittently picking up the input slot from the other subscriber radio directly (not through the repeater).If the portables could transmit on one slot and then receive on another it could work like a regular repeater. I think...
