Anytone Anytone 878 (UV or UVIIPlus) Firmware 3.03 Chinese Model Bug?
AA4BK
Central North Carolina
In applying the latest Firmware 3.03 to my Anytones, I've noticed that in "Device Info" on the radio it now shows Chinese characters where it used to show the English model name. This is a new "feature" since the previous 3.02N. I have set the language to English both in CPS and in the Anytone utility for the boot loader. Is it just me, or are others seeing the same thing with Firmware 3.03?
K4EET
Chaplain
Severn, Maryland, USA
I can’t answer your question just yet but I will be installing the update very soon on my AnyTone AT-D878UVII Plus.
What I need to know is this. I am still at version 2.05 firmware. Do I need to install all of the firmware updates in sequence or does the AnyTone firmware gurus make it possible to immediately jump from (v)2.05 directly to (v)3.03 firmware?
Also, has anybody installed the APRS+BT (v)1.06 update and can verify that it is a good set of code?
73 es 🥳 Happy New Year 🎆 , Dave K4EET
AA4BK
The APRS+BT 1.06 is fine and works very well. The 2.00 version is included with the 3.03 firmware zip file so you might just want to install that one. And no you don't have to install them in sequence. If you just get 3.03 and install it that fully updates your firmware. It includes everything so there's no need to install all the previous updates first.
K4EET
Chaplain
Thanks for the information. I will try to get the updates installed today or Saturday.
73, Dave K4EET
K4EET
Chaplain
Now running FW (v)3.03
No Chinese characters under “Device Info”
Also installed APRS+BT (v)1.06
Have not tested APRS+BT.
Also installed the new Icon set.
The new icons are better, e.g. the GPS icon now looks like a satellite.
I’ll keep you posted on my testing.
73 es HAPPY NEW YEAR !!! Dave K4EET
AA4BK
Thanks for the info @K4EET ! Mine aren't doing it any more either btw. I did another MCU reset and full reload, and they're fine now. I know they do need a full MCU reset after a firmware update and I thought I had done that already but there was a lot going on that day and I'm wondering now if I accidentally skipped that part in the middle of everything. Either way, they're all working now. Thanks again!
