Anytone Anytone 878 uv plus Speaker problems
RFccw
Hey everyone, hoping you all can help me. I was programming my anytone 878 (which I have had for about a year) last night. After I got done programming it and went to test the new dmr repeaters I added. The internal speaker is not working. The mic is and it is transmitting, as well as if I plug in a headset or speaker mic to it. But nothing from the internal speaker. It seems to coincidental for the speaker to fail right as I programmed it. Is there some setting I might have missed or something I am overlooking? Thanks for the help this is really frustrating.
RFccw
Yes, there is no audio from internal speaker only when i plug in a headset or speaker mic.
RFccw
I even reinitialized the radio..
i think maybe the speaker went bad, not sure what else it could be
dazey77
Possibly the headset jack switch failing and always thinking a jack is in? More likely than a speaker failing
dickie757
Wired
Out of range
Remove battery, get a stiff wire, like center of bread-tie, put a small angle at the end, about 1/16" bent 10° off straight. Rake the mic and speaker ports and get the crud out of it.
Or, get the appropriate size plug as a single, and insert and remove a hundred times.
Or, take it apart and test it.
If you break it, no biggie, it was already broken. If you fix it, you learned something.
RFccw
I pulled the programming cable out, an earpiece plug, and the speaker mic a bunch of time before this to no avail. When I read your message I thought what the hell let me try it again. Finally after like 15 more times it worked! Hallelujah, thank you!
FKimble
Newnan, GA
This is normal operation on all my radios!
Frank
