Anytone Tech (aka Baofeng Tech) is deliberately misleading consumers.
rapidcharger
The land of broken calculators.
Just a typo correction. The certification was offlined, pending corrections.
I'm curious. Did you even read the dismissal letter?
Since it was buried 2 pages back, here it is again.
12dbsinad
The bottom line here is these units are not certified, in the past or to this present day. So, why they started marketing these radios before rubber stamped is beyond me. I do know one thing, it is not fair for the customers who are purchasing these with basically bogus FCC cert numbers printed on the radios, and marketed as legal to use in the US. I would assume Anytone Tech does not want a wide spread request for refunds. But then again, it's not our fault they are not properly certified when marketed as such.
prcguy
Looking through the dismissal letter I believe many of the problems can be overcome with a firmware update that fixes power levels for FRS and occupational vs uncontrolled use, BW and frequency steps. That leaves the separate part 90 cert and prior versions of the radio have been issued part 90 cert, so that doesn't sound like a big hurdle.
The fact the radio must be booted up in the specific FRS, GMRS or MURS mode might satisfy part 95.655(d). It will be interesting to see where this goes.
prcguy
KD8DVR
Columbus, Ohio
Corrected I stand. I wonder how he's gonna fix that one! I'm now wondering if he is in fact doing a whitewash job? Hmm.... it may be getting close to me issuing that apology or "you told me so" I mentioned some pages back.
nd5y
Wichita Falls, TX
You're wrong. They were certified for a few weeks. The FCC issued the Part 95 A and J certification grants on 3/9/15 then dismissed them on 3/27/15. The part 90 grant is still good as far as I can tell.
12dbsinad
You're wrong. They were certified for a few weeks. The FCC issued the Part 95 A and J certification grants on 3/9/14 then dismissed them on 3/27/14. The part 90 grant is still good as far as I can tell.
Well, I must have missed that part. But again, if it's been dismissed would you agree marketing should reflect that? At least until a new certification is acquired? Also, they mention only a typo in power levels in a response email when clearly it's more than that. Why not mention whats really going on to the customers?
FrankNY
New York, NY
nd5y, I think that you meant "15" rather than "14", right?
As to the Part 90 certification, it really is for another product, isn't it?
Frank.
nd5y
Wichita Falls, TX
Yep. Damned numbers all look the same.
From what can tell they took the exact same boards from an existing part 90 certified product (AT-3318 or whatever it is) and put them in a different plastic case with new firmware that allows locking it down on GMRS or MURS frequencies and then applied for part 95 certification. That is why they have (or had) two FCC IDs.
Voyager
Yep. Been saying that since day one. So, the Part 90 cert is still valid.
MTS2000des
5B2_BEE00 Czar
Looks like someone needs to get to busy to make it work and reapply.
Doesn't matter, the existing products with the dismissed ID's are still not valid if they are issued a new FCC ID number, it isn't on THAT product with the corrected issues. The product has to be re-submitted and re-certified. As the letter clearly states, a NEW FCC ID will be issued if the product is in fact, re-certified with the problems corrected.
This does NOTHING for the presumably hundreds or thousands who, in good faith, handed this "company" money for a product that was advertised as being certified under false pretenses.
It's very clear the me they tried to pull one over on Uncle Charlie and got caught. End of story.
Anytone Tech: refund people's money or expect them to sue you. Anytone Tech customers: better hope you used a real credit card, something tells me you will have a hard time getting them in court. Good luck serving them at the US Post office in Arlington, SD or getting a real address to send a process server to the mysterious "Greg Wilson"
First of all, why are people being "armchair lawyers"? I understand that everyone has an opinion, but when I see a letter which is FABRICATED I tend to feel the need to weigh in.
Now that you have proven yourself to wrong, would you like to apologize? The letter isn't fabricated, if you actually searched the OET site you'd find it, in clearly visible black and white "photostatic copy"...Anytone Tech "stole fizzly lifting drinks"..
GOOD DAY SIR.
:D
I'm still waiting...
rapidcharger
The part 90 grant was issued for a COMPLETELY DIFFERENT RADIO. These 8R series radios are not included in the grants for those completely different models.
It is akin to using the EPA fuel economy ratings for a hyundai accent for a GMC Yukon. It belongs to a different model.
Frank.
Yes, it is. It's the 3318UV model and some others.
Valid for another radio but not these.
Voyager
Wasn't this solved early on in this thread? The radio itself (not the case) is identical. I thought pics were posted in this very thread (or maybe the other one).
The FCC has stated that T/A can be used on models without the requirement for a new TA as long as the only difference is marketing.
Anytone is the same radio as Anytone.
The FCC TA was for the 3318. It also covers the 3318-A, 3318-C, 3318-D, 3318-E, and the 8R series which are all the same radio just with different cases and different firmware.
I know there is a witch hunt for AnytoneTech, but come on, guys - be realistic. Anytone is no different from Anytone.
rapidcharger
Wasn't this solved early on in this thread? The radio itself (not the case) is identical. I thought pics were posted in this very thread (or maybe the other one).)))
The authorization letter for the part 90 grant lists specific modes. the 8R series are not amongst those models. Whether the radio is identical or not, it is not the same model and the attestation letter makes no mention of them being identical to the 3318 series or those other models, just that they were identical to the other 8R series radios. That is my understanding of the situation.
The FCC has stated that T/A can be used on models without the requirement for a new TA as long as the only difference is marketing.)))
Right but so long as the applicant attests to that fact. And that hasn't been done.
Either way, it's a moot point because the radios do not comply with, nor meet the standards for part 90.
Not only that! But they submitted photos of the label which included only the 8RSERIES id number on the label. The part 90 ID was conveniently left out of that photo in the application.
Something tells me this is the beginning of a long string of some more careful examination of the certifications for other frequency agile VFO radios with part 90 grants.
Voyager
Even the 3318 only meet Part 90 when the keypad programming is disabled.
And I thought there was an attestation letter, but...
rapidcharger
The thing I find really amazing about all this is that with all the incredible, unbelievable claims Anytone Tech has made about their radios achieving certification when all others didn't, and only a few people bother to fact check it.
And then the people who don't bother to fact check it because it involves; Ugh...Reading...oh barf! that they later go on to regard the person who exposes it and provide heaps of evidence as incredulous instead of the deceptive liar who continues to lie and take people's money.
I just can't wrap my mind around that.
MTS2000des
5B2_BEE00 Czar
All Right... You all told me so. I'm Sorry I doubted you guys. I'll be more attentive in the future and have more of an open mind.
It's okay. It's easy to want something so bad to forget to actually look beyond the surface.
For the record, I have NO PROBLEM WITH CHINESE RADIOS. I have even sung praises of reviews of Baofeng UV-5R and UV-82, on Amazon and other sites. For their intended purpose as hobbyist radios, they are a GREAT way to get into the hobby for little money.
That being said consumers who want a TOOL should be VERY SKEPTICAL of claims of multiple certifications, and should actually LOOK UP the FCC ID on the OET's website and ensure that the product they are buying is truly certified for their intended use, and has the correct emission designators and such.
After all, simply putting a sticker on the back of the radio with an FCC ID on it is meaningless if the radio itself is not actually certified, or that certification is revoked, dismissed or for a completely different product if they are purchasing such a radio to be 100 percent compliant with FCC rules.
Buyers should be VERY CAUTIOUS and only buy from a reputable dealer with a return policy.
This response from AnyTone Tech to one of their customers is just plain B.S. The letter from the FCC CLEARLY says that once an FCC ID is dismissed, that ID number cannot be used again. AnytTone Tech, I am calling you a liar and a sleazebag. You OWE anyone who bought one of these misrepresented now uncertified radios a FULL REFUND should they ask for it. You tried to get one over on the FCC and consumers.
Consumers acted in good faith and paid for a product which you claimed was certified and in fact, you are still selling on your Amazon Web Store as of this post, despite the FCC advising you to cease and desist marketing these to the general public or else face penalties for violating the Comm Act of 1934 so the FCC said.
Shame on AnyTone Tech/Baofeng Tech for trying to get over on people. Shame on them.
