AOR 5700D 2023
G8OEO
Northumberland UK
I particularly like being able to enter a frequency and immediately start a simple unrestricted search either up or down. The AOR3000a can be operated in the same way when required. These two are the only radios I own with that facility.
Most times I don’t need to set up search limits on VFOs or programme a search bank, although of course those options are essential for an occasional unattended search.
EricCottrell
Boston, Ma
The feature that I like most in my AOR radios is the programmable step and step-adjust. Here in the US we have some interesting channel frequencies for narrow band digital modes. Radio systems would get a 25 kHz UHF channel and put two DMR channels on it, one 6.25 kHz below center and the other 6.25 kHz above center. I could program the AOR with a 12.5 kHz step and a 6.25 kHz step adjust. Some very narrow NXDN radios can do 3.125 kHz steps on UHF and 2.5 kHz on VHF. It is great that I can do those step sizes on my older AOR radios that other radios of that era could not do. I found a NXDN trunked system "hiding" on UHF because it used a 3.125 kHz step size for the channel map.
EricCottrell
Boston, Ma
Some more observations...
I remember someone commenting about the spectrum display on the AR-5700D actually being useful and I agree. I spent some time with it and while it is not as pretty as the IC-R8600 one, it works.
I had poor results feeding the IF OUT on the IC-R8600 into a AR-DV1 or the SDRplay for decoding DMR and other digital modes. I think it is due to IF OUT being a regenerated analog signal using a 12-Bit DAC. It is a different story with the 45.05 MHz IF OUT on the AR-5700D. No problem using DSDPlus Fast Lane through a SDRPlay. It would be great if the 12 kHz IF output could be used for decoding more digital modes than just DRM. This would be better than using the IF Out.
The AR-Alpha and AR-5700D have Audio IQ (AIQ) to provide output for DRM. The advantage of the IC-R8600 is audio over USB. The AIQ output on the AR-5700D is the analog line output, so I had to use my iMic USB Audio dongle. SDRSharp and SDRuno also has Audio IQ output, so I can use Virtual Audio Cable. I had to make sure to turn off the automatic mode change in the SDRSharp Bandplan Plug-in for raw mode to stick after a frequency change.
There does not seem to be many programs that support AIQ input. I tried Sigmira 1r13 even though it is not actively developed. While the raw mode of SDRSharp centers the output around zero, the AIQ output of the AR-5700D is centered on 12 kHz. This causes an interesting spectrum display in Sigmira using 30 KHz Bandwidth as the signal crosses zero and gets cut off at about -3 kHz. It stays near zero up to -8.5 kHz, then there is an image. Setting the Bandwidth lower narrows the cutoff closer to 12 kHz.
One minor problem is zero is always in the center of the Sigmira spectrum when using IQ so I had to set the frequency width to 50 kHz. Everything worked fine by just remembering to center the signal at 12 kHz. I was able to sync and have a high FEC level on an encrypted STANAG 4285 signal I suspect is CFH. I tried Multipsk and got the same type of spectrum display, but it was not obvious if it was decoding anything. I find the Multipsk interface too busy. I used Dream DRM set to positive IQ input and synced on several DRM signals, but they were too weak to decode audio.
I did come across a bug with AIQ. I did something so AIQ was just regular line out while tuning around HF. I tried a number of things, including resetting the receiver, and it did not work. I tuned in the local weather on 162 MHz in FM and then switched to AIQ, it worked. If AIQ is not working you get the spectrum above zero mirrored below zero.
Accessory Socket 1 has changed from my other AOR Receivers. I used the Detector Output (Pin 2) in the past on my AR-5000, AR-Alpha, and AR-8600 for digital decoding. It is good to see it is still available for NFM mode on the AR-5700D. They changed the Audio Input (Pin 3) on some receivers to a mute input and the high level audio output (Pin 6) to a GPS time pulse input. There is a stereo line out jack for high level audio.
The swap of the antenna port supporting HF when using I/Q Out is annoying. I played around with SDRSharp on HF and wondered how WBCQ got on 6906 kHz. It turned out the spectrum display was inverted. If I shifted the frequency up, then the spectrum would move to the right, and the frequency ribbon would move to the left. I selected Invert Spectrum in the AOR Settings and then it worked correctly. I then found I needed to select Invert Spectrum below 25 MHz and deselect Invert Spectrum at 25 MHz and above.
I noticed the Auto setting of the Attenuator in the SDRSharp AOR control panel did not seem to work. It was set to Auto with the preamp on. I went to Manual and turned the preamp off. It remained off when I went back to Auto, but I returned it to Manual. It was interesting with the preamp on as I got normal signals when tuned to WWV at 10 MHz, but the noise floor went up and I heard audio from multiple stations when I tuned to a nearby station on 31 Meters. The noise floor went down to normal when I turned off the preamp. I kinda expected this since I am using a Wellbrook Loop and the output is strong. 10 MHz is likely a bandpass filter switch point and there was a strong signal in the passband of the filter used for 31 Meters.
I need to study the SDRsharp Big Book 2024 for more information on the Plugins. Unfortunately it does not cover the changes to support the AOR receivers. More experimentation!
G8OEO
Northumberland UK
I have a VB program set up to make editing memories a bit easier and it's working fine except for one niggle.
I thought it would be useful to accurately set up the radio Date and Time with just the press of a button on the PC and it does appear to correctly send the "CK" command in the form CKYYYYMMDDHHMMSS. eg for the time of this post in the UK it would be something like CK20250704125000 + chr(13)
However the time is not updating on the radio display even though interrogating the clock with a blank CK on the PC suggests it has worked.
Either I'm doing something wrong or there is a bug in the radio. Very confused.
EricCottrell
Boston, Ma
The firmware release notes mentions the latest firmware for the panel (P403B) "fixed the clock command CK which was not working".
G8OEO
Northumberland UK
Thank you Eric, really good to know I wasn’t the cause of the problem. Of course it isn’t important enough to warrant a firmware update unless there are some other improvements worth having. Click-free DMR would definitely be a big plus.
EricCottrell
Boston, Ma
I decided to try out KG-Tone. I found the website was deleted, but putting the URL in the Wayback Machine and selecting the year 2024 allowed me to download the file. I took the readme file and got a good English translation with Google Translate. I first tried it with SDRPlusPlus Brown and did not have much success.
I found instructions in the readme file on using the AIQ output of the AR5001D. I got my old iMic out of the drawer and hooked up the line out of my AR5700D to the line in of the iMic. I followed the settings in the readme, but got hit by many error boxes, including Pow() overflow. I had to use task manager to kill the app. I reran the application and turned down the levels before switching over to IQ in the KG-Tone application. It worked and I had solid decode of CTCSS and DCS. Since line out is unaffected by the AR5700D volume level, I turned the AR5700D volume all the way down. KG-Tone demodulates the 12 kHz AIQ output, so I used the Volume and Squelch on KG-Tone.
I have included the Google English translation of the readme.
  • readme_EN.txt
EricCottrell
Boston, Ma
I decided to try an old Optoelectronics DC440 that I bought used with an AOR AR-5000 years ago. The AR-5700D still has a detector output on pin2 of ACC 1, but is limited to NFM mode. I found the mini-DIN to 3.5MM audio jack adapter I made years ago, an 3.5MM audio cable, and connected the DC440 to the AR-5700D. I got excellent results and plan on using the DC440 instead of KG-Tone.
Some of the pins on ACC 1 have changed function. GPS time pulse input (Pin 6) looks interesting. An alternative to the AOR GP-5001 is a 10 MHz GPSDO connected to the 10 MHz reference input.
The AUX2 jack is interesting as it can expand GPS usage in the future, maybe using the GPS to adjust the receiver's clock.
bagmouse7
NC, USA
On my 5001, I have built a cable that connects pin 6 on the front panel ACC1 DIN port (GPS time pulse input) to the 1 PPS source on my GPSDO clock source.
The 5001 starts blinking it's GPS status indicator on the display immediately (0.1 ppm clock) and then after around 30-40 minutes the indicator goes solid indicating a full lock (0.01 ppm clock).
It works great!
EricCottrell
Boston, Ma
I am a lot happier with the AR5700D as I do not have to ship it back to a dealer for firmware updates.
I was successful in updating my AR5700D. The only update I needed was the Panel to 508A. Given how AOR numbers their versions, this is a update from August 2025. I also updated DigiDec as it says to do. I think you do the DigiDec update each time because the updater can not get the version. It is too bad there is no updated firmware version list yet.
I initially had problems because the Null Modem (cross) cable did not work. A straight female-female cable did work. I also discovered a real hardware serial port will not work, likely due to baud rate limitations.
I used a IOGear USB GUC232A Serial Dongle (a rebadged ATEN UC232A). If the serial number is Z3 or Z8 and the third character is a letter, then it has a supported Prolific chip (post-2012). The Windows 10/11 driver I use is v1.1.102 for the ATEN.
When I pressed the Panel button I got a pop-up window with further steps. AOR made updating easier than the AR-Alpha as only a small panel on the bottom of the receiver is removed to change the dip switches. I followed the procedure without any problems.
I went through the procedure for the DigiDec update using the I/Q Out. The I/Q driver has to be installed on the laptop. Again another pop-up windows was displayed when I pressed DigiDec. It does take a while and several OPEN ERROR messages occurred for some reason. The process continued until it displayed success after about 10 minutes. I turned off the receiver by the main power switch in back and turned it back on. Everything still works and the version display reflects the new firmware. My receiver now has:
Main_403AR D4NC P508A
wb4sqi
Amelia, OH
About time they wised up to allow users to do the update.
EricCottrell
Boston, Ma
I looked at the log file from the firmware update and the updater can get the DigiDec version. My receiver had a DigiDec version of 307A and it was upgraded to 507A. 307A is not listed in the Release Notes. Hopefully we can get an updated firmware release notes soon.
MainBoard (2): 403AR => 403AR
Decorder (2): 4NCA => 4NCA
Panel (1): 403B => 508A
DigiDec (1): (307A)=> 507A
kdeke
Usa
I also updated, with same remarks as Mr Cotrrell above for the serial cable(use straight). The builtin hardware serial port was used on WIN10, which in my case did work. However, on WIN10 I got a virus warning after package download from AOR JA, so I needed to temporary disable the builtin virus scanner to get the thingie working.
EricCottrell
Boston, Ma
Thanks. I retried my built-in hardware serial port and it worked. I did not have it setup correctly the first time.
EricCottrell
Boston, Ma
I looked at this further and the updater is not getting the DigiDec version from the radio. If I looked at my updated radio, it still says (307A) in the log even though the update was successful. This might be why it is in parentheses and AOR wants it to always be updated.
Beside the slight errors in the procedure, like the wrong serial cable type, one big omission is the missing Firmware Release Notes. AOR should at least put it on their website. It was great that a forum member posted the February 2025 version, but it is something that AOR really should provide more directly.
to2way
Toronto
So do we have consensus..... this is worth trying?
Do we have validation of claims it messes with the SD-card recordings? Any other issues post upgrade?
I have a really early model that needs this but the process / instructions have been optimized by those here (with thanks!) so really want to go ahead and do it!
G8OEO
Northumberland UK
I’m very happy because for me DMR reception has been improved compared with my previous roughly 2 year old firmware.
I can confirm there is a problem replaying existing SD recordings which I know were ok. They sound distorted and speeded up.
I haven’t bothered trying to record any new ones. I can live without audio recordings until the next update.
to2way
Toronto
thanks for that perspective!
EricCottrell
Boston, Ma
I have a couple of recordings made with the original firmware (Main_403AR D4NC P403B) and they play okay with the updated firmware (Main_403AR D4NC P508A). I also did another recording with the updated firmware and it played okay.
I suspect AOR may have changed the audio sampling rate. I looked at the rate in Audacity and the files have a sample rate of 17578. I wonder if the original rate was 16000, which would make the file play faster on a later radio. The radio may not read the sample rate in the file because record is usually the same rate as playback.
One solution is to use Audacity or other programs on Windows to play the older files. I did not have any problems playing the files with Windows Media Player or VLC on Windows 10.
G8OEO
Northumberland UK
Just made a new recording and along with the older ones it doesn't play back correctly on my updated radio.
Using Windows media player old files are fine but the new file sounds like it is playing at around half the recorded speed!
Both the older files and the new one claim on examination to have been sampled at 17,578 Hz but it's as if a much higher rate is now being used by the radio and the WAV header info has remained the same.
So in my case the radio appears to be hopelessly bugged in both recording and playback.
